[Geomoose-users] Some layers print, some don't
Eli Adam eadam at co.lincoln.or.us
Fri Aug 9 11:17:59 PDT 2013
On Fri, Aug 9, 2013 at 10:01 AM, Bistrais, Bob <Bob.Bistrais at maine.gov>wrote:
>  I think that would be a good idea.
Please read through the existing docs and then make a specific
recommendation of change (or open a ticket with the suggestion) and I will
do it.
Eli
> *From:* James Klassen [mailto:klassen.js at gmail.com]
> *Sent:* Friday, August 09, 2013 12:51 PM
> *To:* Bistrais, Bob
> *Cc:* geomoose-users at lists.osgeo.org
> *Subject:* Re: [Geomoose-users] Some layers print, some don't****
> Is this something that should be clarified in the docs?
> On 2013/8/9 8:56 AM, Bistrais, Bob wrote:****
> With a shout-out to Mark for his help, I have this issue resolved.  Turned
> out it was the server name in the ini file.  Localhost worked on the
> development machines, but I needed the server name for the test server (and
> I imagine the production server when the time comes). ****
> *From:* Jim Klassen [mailto:klassen.js at gmail.com <klassen.js at gmail.com>]
> *Sent:* Thursday, August 08, 2013 5:47 PM
> *To:* Bistrais, Bob
> You might be on the right track w.r.t. to looking a temp directory issue.*
> On Aug 6, 2013, at 11:45 AM, Bistrais, Bob wrote:****
> The saga of my printing woes continues.  I got the printing to work
> correctly with my application, consuming some of the WMS services as
> MapServer services to avoid timeout when printing.  This works well on my
> development machine.  But when I transferred the code over to a test
> machine, I find that the layers display in the browser just fine, but only
> the remaining “pure” WMS services appear in the print output.  To make it
> even more confusing, I moved the code to my “sandbox” machine,
> configuration pretty much identical to the test server, and everything
> works fine.   Is there an output location setting that I could have
> missed?  Something else?****
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users****
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130809/7a482c44/attachment-0001.html>
More information about the Geomoose-users mailing list
