[Geomoose-users] Unsupported output format (image/png;bits=8)
Brent Fraser bfraser at geoanalytic.com
Tue Aug 13 09:05:05 PDT 2013
Well, I'm confused.  AFAIK, "FORMAT" is not a valid standard mapserver
CGI parameter, and looking at the demo parcels.map file, we're not doing
mapserver run-time substitution.  The mapbook entry might be a
cut-and-paste error from a  WMS entry (is FORMAT valid for WMS?).  Maybe
Geomoose is changing FORMAT to some other keyword?
Ah, never mind the above.  I forgot Geomoose 2.6 does not use mapserver
CGI protocol; it uses WMS protocol to communicate with mapserver...
At any rate, I think there is a bug in our geomoose_globals.map on line 23:
MIMETYPE  "image/png;bits=8"
should be:
MIMETYPE  "image/png; mode=8bit"
Not that it really matters, I don't think mapserver will output an 8 bit
png, but I'd have to do some testing to confirm that.
Best Regards,
Brent Fraser
On 8/13/2013 8:19 AM, Eli Adam wrote:
> On Wed, Aug 7, 2013 at 7:40 AM, Robert R. Raiz <raizrobert at gmail.com
> <mailto:raizrobert at gmail.com>> wrote:
> > I managed to find out the cause of this error. If the param value is
> declared, it will not take consideration of any other OUTPUTFORMAT
> other than the one with MIMETYPE "image/png;bits=8"
> > example of param:
> > <map-source name="parcels" type="mapserver">
> > <file>./demo/parcels/parcels.map</file>
> >                 <layer name="parcels" status="on"/>
> >                 <param name="FORMAT" value="image/png;bits=8"/>
> >  </map-source>
> Tricky.
> I see that you got that from the demo example,
> http://trac.osgeo.org/geomoose/browser/geomoose2/branches/geomoose-2.6/conf/mapbook.xml#L102
> I'm wondering if the documentation should be updated in
> http://www.geomoose.org/docs/mapbook.html#map-source or in the adding
> a layer section or the geomoose_globals.map section of
> http://www.geomoose.org/howto/layer.html
> Is there a reason to include the FORMAT parameter in the mapbook?
> Thoughts?
> Eli
> > If I remove that param, GeoMoose displays any other OUTPUTFORMAT
> from my map template. I did not notice it before as I have a script
> that brings in the mapbook all the layers, params and so on from my
> mapfile.
> > I will come back shortly with my findings on this post as well:
> http://lists.osgeo.org/pipermail/geomoose-users/2013-July/005108.html
> > On Wed, Jul 24, 2013 at 5:02 PM, Robert R. Raiz
> <raizrobert at gmail.com <mailto:raizrobert at gmail.com>> wrote:
> >> Thank you Brent,
> >> Unfortunately, I still get that error even with your settings.
> >> I am using 6.2.1. It appears like it is hardcoded somewhere, dunno.
> The mapfile is quite straightforward, no complicated stuff. The only
> version which works (but does not display png icons well) is the one
> from the first emails. Did not see this type of errors before. Strange.
> >> On Wed, Jul 24, 2013 at 4:53 PM, Brent Fraser
> <bfraser at geoanalytic.com <mailto:bfraser at geoanalytic.com>> wrote:
> >>> Here's the definition I appear to be using:
> >>>     IMAGETYPE AGG_PNG
> >>>     OUTPUTFORMAT
> >>>         NAME  'AGG_PNG'
> >>>         DRIVER AGG/PNG
> >>> #        MIMETYPE "image/png;mode=24bit"
> >>>         MIMETYPE "image/png"
> >>>         IMAGEMODE RGBA    # renders IMAGECOLOR transparent
> >>>         EXTENSION "png"
> >>>         FORMATOPTION "INTERLACE=false"
> >>>         FORMATOPTION "TRANSPARENT=ON"
> >>>         TRANSPARENT ON
> >>>         FORMATOPTION "QUANTIZE_FORCE=ON"
> >>>         FORMATOPTION "QUANTIZE_DITHER=off"
> >>>         FORMATOPTION "QUANTIZE_COLORS=256"
> >>>     END
> >>> Which version of Mapserver are you using?
> >>> Best Regards,
> >>> Brent Fraser
> >>> On 7/24/2013 7:37 AM, Robert R. Raiz wrote:
> >>>> I just tried it out. Both:
> >>>> WEB
> >>>> METADATA
> >>>> 'ows_title' 'Parcel Maps'
> >>>> 'ows_srs' 'EPSG:26915 EPSG:4326 EPSG:900913 EPSG:4269 EPSG:2277'
> >>>> 'ows_enable_request' '*'
> >>>> 'ows_onlineresource' 'http://www.geomoose.org'
> >>>> END
> >>>> END
> >>>> OUTPUTFORMAT
> >>>>  NAME "png8"
> >>>>  DRIVER AGG/PNG8
> >>>>  IMAGEMODE RGB
> >>>>  EXTENSION "png"
> >>>> END
> >>>> And:
> >>>>         OUTPUTFORMAT
> >>>>  NAME "png32"
> >>>>  DRIVER AGG/PNG
> >>>>  MIMETYPE "image/png; mode=32bit"
> >>>>  IMAGEMODE RGBA
> >>>>  EXTENSION "png"
> >>>> END
> >>>> Both return the same error. I think the syntax is quite ok, I do
> not see what could be wrong as there are a few simple lines.
> >>>> If I put DRIVER AGG/PNG32 is returns another
> error: loadOutputFormat(): General error message. OUTPUTFORMAT clause
> references driver AGG/PNG32, but this driver isn't configured.
> >> Raiz Roland Robert
> > Raiz Roland Robert
> > Geomoose-users mailing list
> > Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
> > http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130813/6a0a7ded/attachment-0001.html>
More information about the Geomoose-users mailing list
