[Geomoose-users] [Geomoose for beginner's
James Klassen klassen.js at gmail.com
Tue Aug 27 09:12:03 PDT 2013
conf/mapbook.xml is the default mapbook and is the one that will take
effect unless you have done something special.
I am not sure what mapbook.txt is.  You can ignore mapbook_dev.xml as it
is an artifact from GeoMoose 2.4 or older and is no longer used.
I am not sure what you mean by "change the coordinates of parcel data".
If you mean changing projections:  There are two places projections are
in play.
1) MapServer needs to   know what projection your data is in.  This is
set in the MAP->LAYER->PROJECTION in the mapfile.
http://mapserver.org/mapfile/projection.html
2) GeoMoose needs to know what projection to display the data in.  All
of your map-sources need to be able to render in the projection selected
in GeoMoose.  In the demo this is EPSG:3857 so that the common tiled
basemap layers work (Google, OSM, Bing, etc.)  If you are displaying in
a projection other than EPSG:26915, EPSG:4326 EPSG:900913 or EPSG:3857
then you will need to add it to the list in MAP->WEB-METADATA->"ows_srs".
This second case is covered here:
http://docs.geomoose.org/2.6/docs/projections.html
On 2013/8/27 10:42 AM, Solly Vuso wrote:
> Thank you Jim for replaying
> When I open mapbook I see mapbook.xml and mapbook_dev and two mapbook.txt
> Tell me if am wrong, I want to change the coordinates of parcel data
> in the mapfile and do the same also in mapbook.xml am not sure if I
> should also do the same in mapbook_dev
> On 26 Aug 2013 5:07 PM, "James Klassen" <klassen.js at gmail.com
> <mailto:klassen.js at gmail.com>> wrote:
>     Mapfiles tell MapServer how to access your data and draw your data
>     as a map service.
>     The Mapbook tells GeoMoose how to connect to layers in map
>     services and how to make those layers available in the Catalog.
>     You will need to change the Mapbook to point to your new mapfile.
>     http://docs.geomoose.org/2.6/docs/mapbook.html
>     On 2013/8/26 9:40 AM, Solly Vuso wrote:
>>     Hi Mark
>>     Am new in geomoose, I would like to check when I want to use my
>>     own data wich file to change that will read the mapfile , I have
>>     already created a mapfile and name it parcels with my own data
>>     but I dont know what other file to twirk and make it to read my
>>     parcel mapfile .please help
>>     Thank you
>>     On 26 Aug 2013 3:39 PM, "Mark Volz" <MarkVolz at co.lyon.mn.us
>>     <mailto:MarkVolz at co.lyon.mn.us>> wrote:
>>         Hello
>>         I noticed that everything on the bug tracker is closed and
>>         set to wontfix.  I am just curious as to what is going on.
>>         Thanks
>>         Mark Volz, GISP
>>         GIS Specialist
>>         _______________________________________________
>>         Geomoose-users mailing list
>>         Geomoose-users at lists.osgeo.org
>>         <mailto:Geomoose-users at lists.osgeo.org>
>>         http://lists.osgeo.org/mailman/listinfo/geomoose-users
>>     Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130827/891807c7/attachment.html>
More information about the Geomoose-users mailing list
