[Geomoose-users] [Geomoose for beginner's
Solly Vuso sollyvuso at gmail.com
Fri Aug 30 12:15:33 PDT 2013
Thank you for assisting me
I have one small problem, I don't know which part I have missed
1.I have edited Mapfile for parcels , the extent and the projection (I have
created my own shapefile and rename it parcels)
2. I have changed also the Mapbook.xml (I added EPSG in that list and also
changed the extent of parcels under Jump to)
3. I have replaced the parcels shapefile with my own shapefile but using
the same name
The only problem I get on the browser is blank where it suppose to be a map
I have attached the mapbook.xml and parcels.mapfile
On Tue, Aug 27, 2013 at 6:12 PM, James Klassen <klassen.js at gmail.com> wrote:
>  conf/mapbook.xml is the default mapbook and is the one that will take
> effect unless you have done something special.
> I am not sure what mapbook.txt is.  You can ignore mapbook_dev.xml as it
> is an artifact from GeoMoose 2.4 or older and is no longer used.
> I am not sure what you mean by "change the coordinates of parcel data".
> If you mean changing projections:  There are two places projections are in
> play.
> 1) MapServer needs to   know what projection your data is in.  This is set
> in the MAP->LAYER->PROJECTION in the mapfile.
> http://mapserver.org/mapfile/projection.html
> 2) GeoMoose needs to know what projection to display the data in.  All of
> your map-sources need to be able to render in the projection selected in
> GeoMoose.  In the demo this is EPSG:3857 so that the common tiled basemap
> layers work (Google, OSM, Bing, etc.)  If you are displaying in a
> projection other than EPSG:26915, EPSG:4326 EPSG:900913 or EPSG:3857 then
> you will need to add it to the list in MAP->WEB-METADATA->"ows_srs".
> This second case is covered here:
> http://docs.geomoose.org/2.6/docs/projections.html
> On 2013/8/27 10:42 AM, Solly Vuso wrote:
> Thank you Jim for replaying
> When I open mapbook I see mapbook.xml and mapbook_dev and two mapbook.txt
> Tell me if am wrong, I want to change the coordinates of parcel data in
> the mapfile and do the same also in mapbook.xml am not sure if I should
> also do the same in mapbook_dev
> On 26 Aug 2013 5:07 PM, "James Klassen" <klassen.js at gmail.com> wrote:
>>  Mapfiles tell MapServer how to access your data and draw your data as a
>> map service.
>> The Mapbook tells GeoMoose how to connect to layers in map services and
>> how to make those layers available in the Catalog.  You will need to change
>> the Mapbook to point to your new mapfile.
>> http://docs.geomoose.org/2.6/docs/mapbook.html
>> On 2013/8/26 9:40 AM, Solly Vuso wrote:
>> Hi Mark
>> Am new in geomoose, I would like to check when I want to use my own data
>> wich file to change that will read the mapfile , I have already created a
>> mapfile and name it parcels with my own data but I dont know what other
>> file to twirk and make it to read my parcel mapfile .please help
>> Thank you
>> On 26 Aug 2013 3:39 PM, "Mark Volz" <MarkVolz at co.lyon.mn.us> wrote:
>>> Hello
>>> I noticed that everything on the bug tracker is closed and set to
>>> wontfix.  I am just curious as to what is going on.
>>> Thanks
>>> Mark Volz, GISP
>>> GIS Specialist
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
>> Geomoose-users mailing listGeomoose-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geomoose-users
Best Regards
Solly Vuso
Cell:073 3068 170
Fax:086 555 1270
I may not know what tomorrow holds for me but I do know who holds ma
tomorrow.....
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130830/340f8a5a/attachment-0001.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130830/340f8a5a/attachment-0001.obj>
Type: text/xml
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130830/340f8a5a/attachment-0001.xml>
More information about the Geomoose-users mailing list
