[Geomoose-users] [Geomoose for beginner's
Brian Fischer bfischer at houstoneng.com
Fri Aug 30 13:23:01 PDT 2013
These parameters don't look right.
                                <param name="max_extent">-20037508.342789,-20037508.342789,20037508.342789,20037508.342789</param> (I think this needs to match your initial extent)
                                <param name="initial_extent">25.916250,-32.592279 25.937444,-32.580086</param>
What projection did you put your parcel shapefile in?  The way you have your mapfile setup it would have to be in EPSG 4148.
Brian Fischer
Principal | GIS Project Manager
Houston Engineering, Inc.
O 763.493.4522 | D 763.493.6664 | F 763.493.5572
From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Solly Vuso
Sent: Friday, August 30, 2013 2:16 PM
To: James Klassen
Cc: geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] [Geomoose for beginner's
Thank you for assisting me
I have one small problem, I don't know which part I have missed
1.I have edited Mapfile for parcels , the extent and the projection (I have created my own shapefile and rename it parcels)
2. I have changed also the Mapbook.xml (I added EPSG in that list and also changed the extent of parcels under Jump to)
3. I have replaced the parcels shapefile with my own shapefile but using the same name
The only problem I get on the browser is blank where it suppose to be a map
I have attached the mapbook.xml and parcels.mapfile
On Tue, Aug 27, 2013 at 6:12 PM, James Klassen <klassen.js at gmail.com<mailto:klassen.js at gmail.com>> wrote:
conf/mapbook.xml is the default mapbook and is the one that will take effect unless you have done something special.
I am not sure what mapbook.txt is.  You can ignore mapbook_dev.xml as it is an artifact from GeoMoose 2.4 or older and is no longer used.
I am not sure what you mean by "change the coordinates of parcel data".
If you mean changing projections:  There are two places projections are in play.
1) MapServer needs to   know what projection your data is in.  This is set in the MAP->LAYER->PROJECTION in the mapfile.  http://mapserver.org/mapfile/projection.html
2) GeoMoose needs to know what projection to display the data in.  All of your map-sources need to be able to render in the projection selected in GeoMoose.  In the demo this is EPSG:3857 so that the common tiled basemap layers work (Google, OSM, Bing, etc.)  If you are displaying in a projection other than EPSG:26915, EPSG:4326 EPSG:900913 or EPSG:3857 then you will need to add it to the list in MAP->WEB-METADATA->"ows_srs".
This second case is covered here: http://docs.geomoose.org/2.6/docs/projections.html
On 2013/8/27 10:42 AM, Solly Vuso wrote:
Thank you Jim for replaying
When I open mapbook I see mapbook.xml and mapbook_dev and two mapbook.txt
Tell me if am wrong, I want to change the coordinates of parcel data in the mapfile and do the same also in mapbook.xml am not sure if I should also do the same in mapbook_dev
On 26 Aug 2013 5:07 PM, "James Klassen" <klassen.js at gmail.com<mailto:klassen.js at gmail.com>> wrote:
Mapfiles tell MapServer how to access your data and draw your data as a map service.
The Mapbook tells GeoMoose how to connect to layers in map services and how to make those layers available in the Catalog.  You will need to change the Mapbook to point to your new mapfile.
http://docs.geomoose.org/2.6/docs/mapbook.html
On 2013/8/26 9:40 AM, Solly Vuso wrote:
Hi Mark
Am new in geomoose, I would like to check when I want to use my own data wich file to change that will read the mapfile , I have already created a mapfile and name it parcels with my own data but I dont know what other file to twirk and make it to read my parcel mapfile .please help
Thank you
On 26 Aug 2013 3:39 PM, "Mark Volz" <MarkVolz at co.lyon.mn.us<mailto:MarkVolz at co.lyon.mn.us>> wrote:
Hello
I noticed that everything on the bug tracker is closed and set to wontfix.  I am just curious as to what is going on.
Thanks
Mark Volz, GISP
GIS Specialist
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/geomoose-users
Best Regards
Solly Vuso
Cell:073 3068 170
Fax:086 555 1270
I may not know what tomorrow holds for me but I do know who holds ma tomorrow.....
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130830/69012514/attachment.html>
More information about the Geomoose-users mailing list
