[Geomoose-users] How to implement an Atlas with several chapters
TC Haddad tchaddad at gmail.com
Sat Dec 7 08:15:41 PST 2013
Wasn't there also an ability to have multiple Mapbooks that the user could
choose from a dropdown (to switch chapters)? I seem to remember this from
2.4, but haven't seen any examples in 2.6..
maybe this was in Bob's answer which I didn't see go to the list.
On Fri, Dec 6, 2013 at 11:03 AM, Dan Little <theduckylittle at gmail.com>wrote:
> There are a number of people implementing a large collection of layers
> using GeoMOOSE.  I know Bob B with the City of Saint Paul likes to brag
> about 300+ layers in his GeoMOOSE catalog.  100 or so layers will not be
> difficult.  GeoMOOSE has the ability to break up the display of layers into
> groups, those groups can be analogous to chapters.
> Also, the Mapbook is only an XML file.  If you want to create some better
> management tools then I'd suggest the following:
> 1. Create a small django (or Rails or PHP) app that manages the layers in
> your organizations native structure.  You can then use a small web front
> end and database back end to manage the organization.  Then simply write a
> "publish to mapbook" function that write the Mapbook out for the GeoMOOSE
> application.
> 2. Use your favorite text-template language.  For larger projects I'll use
> Mako templates (python based) or a collection of Perl scripts to assemble
> separate files together to make one Mapbook.
> On Fri, Dec 6, 2013 at 4:01 AM, Josef Fürst <josef.fuerst at boku.ac.at>wrote:
>>  I am exploring options to implement a hydrological atlas over the Web.
>> The atlas contains more than 100 thematic maps, organised in 10 chapters.
>> Each of the maps is composed of up to approx. 10 layers, generally
>> shapefiles (and some images). Originally, this atlas was published on
>> CD-ROM, together with a ESRI Mapobjects LT based viewer software.
>> GeoMoose appears to be an attractive platform for implementing the atlas
>> on the WWW at first sight, but I am not sure about the organisation of so
>> many maps. I thought, multiple mapbooks could be a solution, but following
>> the discussion on this list, this seems not to be a natural (and efficient)
>> approach.
>> I would be grateful for all recommendations based on GeoMoose, but also
>> on alternative products. I am hesitating to go down to tools like
>> OpenLayers.
>> Regards,
>> Josef Fuerst
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20131207/bd5a6d1b/attachment.html>
More information about the Geomoose-users mailing list
