[Geomoose-users] Antw: Re: How to implement an Atlas with several chapters
Josef Fürst josef.fuerst at boku.ac.at
Sat Dec 7 02:21:08 PST 2013
Dear Dan and Bob,
thank you for your prompt and comprehensive replies.
First, all the maps are already existing, including allocation to a
specific chapter (e.g. Precipitation, Surface waters, Groundwater,
etc.). There might be some smaller updates and/or extensions in the
future, but realistically only a small percentage of what already
exists. My goal is rather to maintain convenient access to a valuable
amount of information after the existing CDROM and MapObjects based
version runs out of being useable.
With more than 100 maps in one mapbook, users would get lost.
Therefore, I like the idea of developing a small frontend that generates
the desired mapbook on the fly (if I understood you right). For one map
with 3-10 layers, GeoMoose is just what I have in mind.
May I ask you another question? In our current MapObjects/Windows based
atlas viewer, we had implemented some neat hotlink tools for some of the
map layers in Visual Basic. e.g., clicking a stream gauge on the map
with the hydrograph tool, the daily streamflow data for the last 30
years would be downloaded and the hydrograph be visualised in a popup
window.
Do you think it is feasible to add such functionality also in a
GeoMoose context? If yes, which tools/language would you recommend?
Gratefully,
Josef Fuerst
>>> Dan Little <theduckylittle at gmail.com> 06.12.2013 20:03 >>>
There are a number of people implementing a large collection of layers
using GeoMOOSE. I know Bob B with the City of Saint Paul likes to brag
about 300+ layers in his GeoMOOSE catalog. 100 or so layers will not be
difficult. GeoMOOSE has the ability to break up the display of layers
into groups, those groups can be analogous to chapters.
Also, the Mapbook is only an XML file. If you want to create some
better management tools then I'd suggest the following:
1. Create a small django (or Rails or PHP) app that manages the layers
in your organizations native structure. You can then use a small web
front end and database back end to manage the organization. Then simply
write a "publish to mapbook" function that write the Mapbook out for the
GeoMOOSE application.
2. Use your favorite text-template language. For larger projects I'll
use Mako templates (python based) or a collection of Perl scripts to
assemble separate files together to make one Mapbook.
On Fri, Dec 6, 2013 at 4:01 AM, Josef Fürst <josef.fuerst at boku.ac.at>
wrote:
I am exploring options to implement a hydrological atlas over the Web.
The atlas contains more than 100 thematic maps, organised in 10
chapters. Each of the maps is composed of up to approx. 10 layers,
generally shapefiles (and some images). Originally, this atlas was
published on CD-ROM, together with a ESRI Mapobjects LT based viewer
software.
GeoMoose appears to be an attractive platform for implementing the
atlas on the WWW at first sight, but I am not sure about the
organisation of so many maps. I thought, multiple mapbooks could be a
solution, but following the discussion on this list, this seems not to
be a natural (and efficient) approach.
I would be grateful for all recommendations based on GeoMoose, but also
on alternative products. I am hesitating to go down to tools like
OpenLayers.
Regards,
Josef Fuerst
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20131207/3093b0d6/attachment.html>
More information about the Geomoose-users mailing list
