[Geomoose-users] How to implement an Atlas with several chapters
Dan Little theduckylittle at gmail.com
Fri Dec 6 11:03:27 PST 2013
There are a number of people implementing a large collection of layers
using GeoMOOSE.  I know Bob B with the City of Saint Paul likes to brag
about 300+ layers in his GeoMOOSE catalog.  100 or so layers will not be
difficult.  GeoMOOSE has the ability to break up the display of layers into
groups, those groups can be analogous to chapters.
Also, the Mapbook is only an XML file.  If you want to create some better
management tools then I'd suggest the following:
1. Create a small django (or Rails or PHP) app that manages the layers in
your organizations native structure.  You can then use a small web front
end and database back end to manage the organization.  Then simply write a
"publish to mapbook" function that write the Mapbook out for the GeoMOOSE
application.
2. Use your favorite text-template language.  For larger projects I'll use
Mako templates (python based) or a collection of Perl scripts to assemble
separate files together to make one Mapbook.
On Fri, Dec 6, 2013 at 4:01 AM, Josef Fürst <josef.fuerst at boku.ac.at> wrote:
>  I am exploring options to implement a hydrological atlas over the Web.
> The atlas contains more than 100 thematic maps, organised in 10 chapters.
> Each of the maps is composed of up to approx. 10 layers, generally
> shapefiles (and some images). Originally, this atlas was published on
> CD-ROM, together with a ESRI Mapobjects LT based viewer software.
> GeoMoose appears to be an attractive platform for implementing the atlas
> on the WWW at first sight, but I am not sure about the organisation of so
> many maps. I thought, multiple mapbooks could be a solution, but following
> the discussion on this list, this seems not to be a natural (and efficient)
> approach.
> I would be grateful for all recommendations based on GeoMoose, but also on
> alternative products. I am hesitating to go down to tools like OpenLayers.
> Regards,
> Josef Fuerst
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20131206/65a17df5/attachment.html>
More information about the Geomoose-users mailing list
