[Geomoose-users] WMS not working
Paul Wickman paul at flatrockgeo.com
Wed Jul 3 13:19:37 PDT 2013
Ah, ok.  I expect that's the problem.  The 3857 projection is for "Web
Mercator", aka "Google Projection".  The MnGeo WMS service that you're
trying to hit only provides imagery in UTM15N (26915).
However, there is a solution!  Try using the following.  The URL specified
here serves the same imagery in the project that you need.
<map-source name="fsa2010" type="wms" projection='EPSG:3857'>
                <url>http://geoint.lmic.state.mn.us/cgi-bin/wmsll?</url>
                 <layer name="fsa2010" />
                <param name="TRANSPARENT" value="true"/>
                <param name="FORMAT" value="image/jpeg"/>
</map-source>
On Wed, Jul 3, 2013 at 3:07 PM, Dennis Tumberg <
dtumberg at invergroveheights.org> wrote:
> It is not, it is set to:****
> <param name="projection">EPSG:3857</param>****
> *From:* Paul Wickman [mailto:paul at flatrockgeo.com]
> *Sent:* Wednesday, July 03, 2013 3:07 PM
> *To:* Dennis Tumberg
> *Cc:* geomoose-users at lists.osgeo.org
> *Subject:* Re: [Geomoose-users] WMS not working****
> Is your mapbook.xml set to the same projection (26915)?****
> <param name="projection">EPSG:26915</param>****
> On Wed, Jul 3, 2013 at 3:01 PM, Dennis Tumberg <
> dtumberg at invergroveheights.org> wrote:****
> Sorry, I had copied that to post it, but switched it to “on” before I
> posted, nothing worked.  I deleted status all together, it is still not
> working.****
> *Dennis Tumberg*****
> GIS Technician****
> City of Inver Grove Heights****
> Phone - 651.554.3446****
> *Sent:* Wednesday, July 03, 2013 2:57 PM
> Dennis,****
> At first glance, try removing the ' status="off" ' setting on the <layer>
> On Wed, Jul 3, 2013 at 2:23 PM, Dennis Tumberg <
> I have been working with GeoMOOSE just a short time and am having issues
> with getting a WMS layer to display.****
> I have tried adding the WMS directly with and without a MAP file.****
> Here is what I have for the map source and layer in catalog:****
> <map-source name="fsa2010" type="wms" projection='EPSG:26915'>****
>                 <url>http://geoint.lmic.state.mn.us/cgi-bin/wms?</url>****
>                  <layer name="fsa2010" status="off"/>****
>                 <param name="TRANSPARENT" value="true"/>****
>                 <param name="FORMAT" value="image/png"/>****
> </map-source>****
> <layer title="2010 FSA" src="fsa2010/fsa2010" status="off" legend="false"
> fade="false" unfade="false"/>****
> What am I doing wrong, I can’t seem to find any of the solutions with
> online searches.****
> Thanks,****
> GIS Technician****
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users****
> Paul Wickman
> CTO | Flat Rock Geographics
> 612.280.5850 | paul at flatrockgeo.com
> www.flatrockgeo.com | twitter.com/flatrockgeo ****
> Paul Wickman
Paul Wickman
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130703/7faf4d0c/attachment-0001.html>
More information about the Geomoose-users mailing list
