[Geomoose-users] WMS not working
Dennis Tumberg dtumberg at invergroveheights.org
Wed Jul 3 13:26:47 PDT 2013
Paul,
That worked!  Thanks for your help with this.  So, is it possible to use WMS layers that are in a different coordinate system, or is that not possible in GeoMOOSE?  I was looking at adding aerials that were originally in Dakota County Coordinates and in UTM coordinates.  Before I get to far into this I should find out if that is even possible or not.
Thanks!
From: Paul Wickman [mailto:paul at flatrockgeo.com]
Sent: Wednesday, July 03, 2013 3:20 PM
To: Dennis Tumberg
Cc: geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] WMS not working
Ah, ok.  I expect that's the problem.  The 3857 projection is for "Web Mercator", aka "Google Projection".  The MnGeo WMS service that you're trying to hit only provides imagery in UTM15N (26915).
However, there is a solution!  Try using the following.  The URL specified here serves the same imagery in the project that you need.
<map-source name="fsa2010" type="wms" projection='EPSG:3857'>
                <url>http://geoint.lmic.state.mn.us/cgi-bin/wmsll?</url>
                 <layer name="fsa2010" />
                <param name="TRANSPARENT" value="true"/>
                <param name="FORMAT" value="image/jpeg"/>
</map-source>
On Wed, Jul 3, 2013 at 3:07 PM, Dennis Tumberg <dtumberg at invergroveheights.org<mailto:dtumberg at invergroveheights.org>> wrote:
It is not, it is set to:
<param name="projection">EPSG:3857</param>
From: Paul Wickman [mailto:paul at flatrockgeo.com<mailto:paul at flatrockgeo.com>]
Sent: Wednesday, July 03, 2013 3:07 PM
To: Dennis Tumberg
Cc: geomoose-users at lists.osgeo.org<mailto:geomoose-users at lists.osgeo.org>
Is your mapbook.xml set to the same projection (26915)?
<param name="projection">EPSG:26915</param>
On Wed, Jul 3, 2013 at 3:01 PM, Dennis Tumberg <dtumberg at invergroveheights.org<mailto:dtumberg at invergroveheights.org>> wrote:
Sorry, I had copied that to post it, but switched it to "on" before I posted, nothing worked.  I deleted status all together, it is still not working.
Dennis Tumberg
GIS Technician
City of Inver Grove Heights
Phone - 651.554.3446<tel:651.554.3446>
Sent: Wednesday, July 03, 2013 2:57 PM
To: Dennis Tumberg
Dennis,
At first glance, try removing the ' status="off" ' setting on the <layer>
On Wed, Jul 3, 2013 at 2:23 PM, Dennis Tumberg <dtumberg at invergroveheights.org<mailto:dtumberg at invergroveheights.org>> wrote:
I have been working with GeoMOOSE just a short time and am having issues with getting a WMS layer to display.
I have tried adding the WMS directly with and without a MAP file.
Here is what I have for the map source and layer in catalog:
<map-source name="fsa2010" type="wms" projection='EPSG:26915'>
                <url>http://geoint.lmic.state.mn.us/cgi-bin/wms?</url>
                 <layer name="fsa2010" status="off"/>
                <param name="FORMAT" value="image/png"/>
</map-source>
<layer title="2010 FSA" src="fsa2010/fsa2010" status="off" legend="false" fade="false" unfade="false"/>
What am I doing wrong, I can't seem to find any of the solutions with online searches.
Thanks,
Dennis Tumberg
GIS Technician
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/geomoose-users
Paul Wickman
CTO | Flat Rock Geographics
612.280.5850<tel:612.280.5850> | paul at flatrockgeo.com<mailto:paul at flatrockgeo.com>
www.flatrockgeo.com<http://www.flatrockgeo.com> | twitter.com/flatrockgeo<http://twitter.com/flatrockgeo>
Paul Wickman
Paul Wickman
612.280.5850 | paul at flatrockgeo.com<mailto:paul at flatrockgeo.com>
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130703/0a7a59c8/attachment-0001.html>
More information about the Geomoose-users mailing list
