[Geomoose-users] Public facing GeoMoose sites as examples.
Ed Boesenberg boesiii at yahoo.com
Mon Jul 22 06:14:00 PDT 2013
If your data is plotting but not at the expected position then that usually
indicates it is a projection problem.  Make sure your mapbbok.xml is using
the correct projection parameter, which is near the top of the mapbook.xml.
How far off are they?
Sent: Monday, July 22, 2013 8:04 AM
To: Ed Boesenberg
Cc: Geomoose Support
Subject: Re: [Geomoose-users] Public facing GeoMoose sites as examples.
Hi Ed
I am not winning and I am not giving up, i get lost on the MAPBOOK.XML. I
have attched my new mapfile and the shapefile. I have used Qgis to create a
mapfile. The only problem i have is that  shapefile doesn't fall where i
want it to be (may be the problem is Mapbook
Thank you
On Wed, Jul 17, 2013 at 5:36 PM, Ed Boesenberg <boesiii at yahoo.com> wrote:
Solly,
My name is Ed not Bob.
When I first started using Geomoose I would take baby steps in modifying the
working version, the steps below may help you in getting started using your
own data. After each step test Geomoose and see if it is still working.
1.       Copy Geomoose folder to somewhere else, so you can restore the
original files if something goes wrong.
2.       Configure Geomoose to zoom to your area of extents and setting the
background to your Google layer of choice.
3.       Copy the Parcels MAP file and rename it
4.       Modify new MAP file contents to suit your needs
a.       EXTENT
b.      UNITS
c.       PROJECTION
d.      LAYER -> NAME
e.      LAYER -> DATA
f.        LAYER -> TYPE
5.       Refer to http://geomoose.org/howto/layer.html for the items below
6.       In MAPBOOK.XML, copy the map-source section for the parcels layer
and rename it
7.       In MAPBOOK.XML, in the layer catalog section copy the parcels layer
and rename it
Ed
Sent: Wednesday, July 17, 2013 7:11 AM
To: Ed Boesenberg
Hi Bob
My projection is WGS 84 and I will attach a shapefile .
I will be using google as a background and I have tried to use Qgis to
create  a mapfile using the data I sent to you as a test but I dont know
where to change inside geomoose folders in order to view my data being
overlapped with Google
Thank you again for responding to my emails
On Tue, Jul 16, 2013 at 4:36 PM, Ed Boesenberg <boesiii at yahoo.com> wrote:
Solly,
The Geomoose website has documentation on it to help you get started, see
the following pages.
http://geomoose.org/docs/projections.html
What projection is your data?
What will you be using as a background? Google, Bing, etc.
What format is your data?
Ed
Sent: Monday, July 15, 2013 5:12 PM
To: Ed Boesenberg
Subject: RE: [Geomoose-users] Public facing GeoMoose sites as examples.
Hi Bob
Not yet , am still not sure where to  start .please help
Thank u
On 15 Jul 2013 5:37 PM, "Ed Boesenberg" <boesiii at yahoo.com> wrote:
Solly,
Did you ever get your Geomoose working with your own data?
Ed
-----Original Message-----
From: sollyvuso at gmail.com [mailto:sollyvuso at gmail.com]
Sent: Thursday, July 11, 2013 8:17 AM
To: boesiii at yahoo.com
HI Bob
I am Solly and am new in Geomoose, I saw the below email and I thought you
the right person to help me, I want to use my own data but I dont know where
to start . I have configured the geomoose and its working
<quote author='boesiii'>
Bob,
A client of mine, who is a water and sewer authority, has a GM 2.4 setup but
unfortunately it is not a public facing. I put together a GeoMoose
application to keep track of all their water and sewer information which
includes, as-built drawings, sanitary sewer videos, pipe sizes,invert
elevations, etc.  I could provide a screen shot if needed.
Ed
View this message in context:
http://geomoose-users.964460.n3.nabble.com/Geomoose-users-Public-facing-GeoM
<http://geomoose-users.964460.n3.nabble.com/Geomoose-users-Public-facing-Geo
Moose-sites-as-examples-tp3741982p3742337.html>
Sent from the Geomoose-users mailing list archive at Nabble.com.
</quote>
Quoted from:
http://osgeo-org.1560.x6.nabble.com/Geomoose-users-Public-facing-GeoMoose-si
<http://osgeo-org.1560.x6.nabble.com/Geomoose-users-Public-facing-GeoMoose-s
ites-as-examples-tp4929506p4929507.html>
_____________________________________
Sent from http://osgeo-org.1560.x6.nabble.com
Best Regards
Solly Vuso
Cell:073 3068 170
Fax:086 555 1270
I may not know what tomorrow holds for me but I do know who holds ma
tomorrow.....
Best Regards
Solly Vuso
Cell:073 3068 170
Fax:086 555 1270
tomorrow.....
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130722/b798d313/attachment.html>
More information about the Geomoose-users mailing list
