[Geomoose-users] Public facing GeoMoose sites as examples.
Solly Vuso sollyvuso at gmail.com
Wed Jul 24 02:42:20 PDT 2013
Hi Ed
now its not even showing where is the data, can you try and zip for me all
the files you have change in geomoose like your own mapfile, mapbook and
etc  and include may be some shapefiles you have used in that i mapfile,
that i believe can also help me to understand
On Mon, Jul 22, 2013 at 3:14 PM, Ed Boesenberg <boesiii at yahoo.com> wrote:
> If your data is plotting but not at the expected position then that
> usually indicates it is a projection problem.  Make sure your mapbbok.xml
> is using the correct projection parameter, which is near the top of the
> mapbook.xml.****
> How far off are they?****
> *From:* Solly Vuso [mailto:sollyvuso at gmail.com]
> *Sent:* Monday, July 22, 2013 8:04 AM
> *To:* Ed Boesenberg
> *Cc:* Geomoose Support
> *Subject:* Re: [Geomoose-users] Public facing GeoMoose sites as examples.*
> Hi Ed****
> I am not winning and I am not giving up, i get lost on the MAPBOOK.XML. I
> have attched my new mapfile and the shapefile. I have used Qgis to create a
> mapfile. The only problem i have is that  shapefile doesn't fall where i
> want it to be (may be the problem is Mapbook****
> Thank you ****
> On Wed, Jul 17, 2013 at 5:36 PM, Ed Boesenberg <boesiii at yahoo.com> wrote:*
> Solly,****
> My name is Ed not Bob.****
> When I first started using Geomoose I would take baby steps in modifying
> the working version, the steps below may help you in getting started using
> your own data. After each step test Geomoose and see if it is still working.
> 1.       Copy Geomoose folder to somewhere else, so you can restore the
> original files if something goes wrong.****
> 2.       Configure Geomoose to zoom to your area of extents and setting
> the background to your Google layer of choice.****
> 3.       Copy the Parcels MAP file and rename it****
> 4.       Modify new MAP file contents to suit your needs****
> a.       EXTENT****
> b.      UNITS****
> c.       PROJECTION ****
> d.      LAYER -> NAME****
> e.      LAYER -> DATA****
> f.        LAYER -> TYPE****
> 5.       Refer to http://geomoose.org/howto/layer.html for the items below
> 6.       In MAPBOOK.XML, copy the map-source section for the parcels
> layer and rename it****
> 7.       In MAPBOOK.XML, in the layer catalog section copy the parcels
> Ed****
> *Sent:* Wednesday, July 17, 2013 7:11 AM
> *To:* Ed Boesenberg****
> Hi Bob****
> My projection is WGS 84 and I will attach a shapefile .****
> I will be using google as a background and I have tried to use Qgis to
> create  a mapfile using the data I sent to you as a test but I dont know
> where to change inside geomoose folders in order to view my data being
> overlapped with Google****
> Thank you again for responding to my emails ****
> On Tue, Jul 16, 2013 at 4:36 PM, Ed Boesenberg <boesiii at yahoo.com> wrote:*
> Solly,****
> The Geomoose website has documentation on it to help you get started, see
> the following pages.****
> http://geomoose.org/docs/projections.html****
> http://geomoose.org/howto/layer.html****
> What projection is your data?****
> What will you be using as a background? Google, Bing, etc.****
> What format is your data?****
> Ed****
> *Sent:* Monday, July 15, 2013 5:12 PM
> *To:* Ed Boesenberg
> *Subject:* RE: [Geomoose-users] Public facing GeoMoose sites as examples.*
> Hi Bob****
> Not yet , am still not sure where to  start .please help ****
> Thank u ****
> On 15 Jul 2013 5:37 PM, "Ed Boesenberg" <boesiii at yahoo.com> wrote:****
> Solly,
> Did you ever get your Geomoose working with your own data?
> Ed
> -----Original Message-----
> From: sollyvuso at gmail.com [mailto:sollyvuso at gmail.com]
> Sent: Thursday, July 11, 2013 8:17 AM
> To: boesiii at yahoo.com
> Subject: Re: [Geomoose-users] Public facing GeoMoose sites as examples.
> HI Bob
> I am Solly and am new in Geomoose, I saw the below email and I thought you
> the right person to help me, I want to use my own data but I dont know
> where
> to start . I have configured the geomoose and its working
> <quote author='boesiii'>
> Bob,
> A client of mine, who is a water and sewer authority, has a GM 2.4 setup
> but
> unfortunately it is not a public facing. I put together a GeoMoose
> application to keep track of all their water and sewer information which
> includes, as-built drawings, sanitary sewer videos, pipe sizes,invert
> elevations, etc.  I could provide a screen shot if needed.
> Ed
> http://geomoose-users.964460.n3.nabble.com/Geomoose-users-Public-facing-GeoM
> oose-sites-as-examples-tp3741982p3742337.html
> Sent from the Geomoose-users mailing list archive at Nabble.com.
> </quote>
> Quoted from:
> http://osgeo-org.1560.x6.nabble.com/Geomoose-users-Public-facing-GeoMoose-si
> tes-as-examples-tp4929506p4929507.html
> _____________________________________
> Sent from http://osgeo-org.1560.x6.nabble.com****
> Best Regards
> Solly Vuso
> Cell:073 3068 170
> Fax:086 555 1270
> I may not know what tomorrow holds for me but I do know who holds ma
> tomorrow..... ****
> Best Regards
> Solly Vuso
> Cell:073 3068 170
> Fax:086 555 1270
> tomorrow..... ****
Best Regards
Solly Vuso
Cell:073 3068 170
Fax:086 555 1270
tomorrow.....
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130724/820a4497/attachment-0001.html>
More information about the Geomoose-users mailing list
