[Geomoose-users] Unsupported output format (image/png;bits=8)
Robert R. Raiz raizrobert at gmail.com
Tue Jul 23 07:10:24 PDT 2013
Hello Mark,
Sorry, I forgot to mention that I am not using at all geomoose_globals.map
I've set my parameters to use my simbolset, fonts.. the only thing I kept
from geomoose_globals. map is the WEB-METADATA section.
If I paste in the mapfile what you just forwarded..well..I keep getting the
same message:
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM "
http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1">
<ServiceException code="InvalidFormat">
msWMSLoadGetMapParams(): Image handling error. Unsupported output format
(image/png;bits=8).
</ServiceException>
</ServiceExceptionReport>
I tried all the outputformats in the mapserver documentation but I keep
getting this error. I thought it is hard-coded somewhere to use the
outputformat mentioned in the first email.
On Tue, Jul 23, 2013 at 4:33 PM, Mark Volz <MarkVolz at co.lyon.mn.us> wrote:
>  Robert,****
> geomoose_globals.map, which is included on most of the demo map files
> assigns png8 as the default output format.  This format works well for
> vector layers, but not raster layers.  You might want to change your map
> file like such:****
> #do not include geomoose globals which uses png8****
> #Include ../ geomoose_globals.map****
> #add the portions from geomoose_globals that you need****
>                 FONTSET              "../../fonts/fontset.list"****
>                 SYMBOLSET        "../../symbols/symbol.sym"****
>                 # prevent the pink screen of death on large monitors****
>                 MAXSIZE 10000****
>                 #TRANSPARENT TRUE****
>                 # Does this stuff even need to be set in MS 6.x?  JSK****
>                 OUTPUTFORMAT****
>                                 NAME 'agg/png'****
>                                 DRIVER AGG/PNG****
>                                 IMAGEMODE RGBA****
>                                 FORMATOPTION "TRANSPARENT=TRUE"****
>                                 TRANSPARENT ON****
>                                 MIMETYPE "image/png"****
>                 END ****
>                 IMAGETYPE agg/png    # use the output format named
> ‘agg/png’****
>                 IMAGECOLOR 255 255 255****
> Mark Volz, GISP****
> GIS Specialist****
> *From:* geomoose-users-bounces at lists.osgeo.org [mailto:
> geomoose-users-bounces at lists.osgeo.org] *On Behalf Of *Robert R. Raiz
> *Sent:* Tuesday, July 23, 2013 8:04 AM
> *To:* geomoose-users at lists.osgeo.org
> *Subject:* Re: [Geomoose-users] Unsupported output format
> (image/png;bits=8)****
> Sorry, somehow gmail keyboard shortcuts made a fool out of me and sent the
> email to soon;
> The problem is that now, all my png images (PIXMAP) render really badly.
> They look quite bad.
> Whatever I try to modify in the map file at the OUTPUTFORMAT parameter, I
> keep getting:****
> <ServiceException code="InvalidFormat">****
> (image/png;bits=8).****
> I tried to change every parameter but I still get that error. If I use MIMETYPE
> "image/png;bits=8" it works with vector files, but my icons (PIXMAP - png
> images) do not render well.
> Any Ideas?****
> On Tue, Jul 23, 2013 at 4:00 PM, Robert R. Raiz <raizrobert at gmail.com>
> wrote:****
> Hello all,
> I am struggling with this error.
> In the past (with Mapserver5) I was using:
>   IMAGETYPE png24****
> OUTPUTFORMAT****
> NAME 'AGGA'****
> DRIVER 'AGG/PNG'****
> IMAGEMODE RGBA****
> EXTENSION "png"****
> END  ****
> Now I have:****
> OUTPUTFORMAT****
> NAME "png8"****
> DRIVER AGG/PNG8****
> MIMETYPE "image/png;bits=8"****
> EXTENSION "png"****
> TRANSPARENT ON****
> IMAGEMODE RGBA****
> FORMATOPTION "QUANTIZE_FORCE=on"****
> FORMATOPTION "QUANTIZE_COLORS=256"****
> FORMATOPTION "INTERLACE=OFF"****
> END****
> *Raiz Roland Robert*
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130723/513e9852/attachment.html>
More information about the Geomoose-users mailing list
