[Geomoose-users] Unsupported output format (image/png;bits=8)
Brent Fraser bfraser at geoanalytic.com
Tue Jul 23 07:53:58 PDT 2013
Try
MIMETYPE  "image/png; mode=8bit"
Best Regards,
Brent Fraser
On 7/23/2013 8:10 AM, Robert R. Raiz wrote:
> Hello Mark,
> Sorry, I forgot to mention that I am not using at all geomoose_globals.map
> I've set my parameters to use my simbolset, fonts.. the only thing I
> kept from geomoose_globals. map is the WEB-METADATA section.
> If I paste in the mapfile what you just forwarded..well..I keep
> getting the same message:
> <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
> <!DOCTYPE ServiceExceptionReport SYSTEM
> "http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
> <ServiceExceptionReport version="1.1.1">
> <ServiceException code="InvalidFormat">
> msWMSLoadGetMapParams(): Image handling error. Unsupported output
> format (image/png;bits=8).
> </ServiceException>
> </ServiceExceptionReport>
> I tried all the outputformats in the mapserver documentation but I
> keep getting this error. I thought it is hard-coded somewhere to use
> the outputformat mentioned in the first email.
> On Tue, Jul 23, 2013 at 4:33 PM, Mark Volz <MarkVolz at co.lyon.mn.us
> <mailto:MarkVolz at co.lyon.mn.us>> wrote:
>     Robert,
>     geomoose_globals.map, which is included on most of the demo map
>     files assigns png8 as the default output format.  This format
>     works well for vector layers, but not raster layers.  You might
>     want to change your map file like such:
>     #do not include geomoose globals which uses png8
>     #Include ../ geomoose_globals.map
>     #add the portions from geomoose_globals that you need
>     FONTSET              "../../fonts/fontset.list"
>     SYMBOLSET        "../../symbols/symbol.sym"
>     # prevent the pink screen of death on large monitors
>     MAXSIZE 10000
>     #TRANSPARENT TRUE
>     # Does this stuff even need to be set in MS 6.x? JSK
>     OUTPUTFORMAT
>     NAME 'agg/png'
>     DRIVER AGG/PNG
>     IMAGEMODE RGBA
>     FORMATOPTION "TRANSPARENT=TRUE"
>     TRANSPARENT ON
>     MIMETYPE "image/png"
>     END
>     IMAGETYPE agg/png    # use the output format named 'agg/png'
>     IMAGECOLOR 255 255 255
>     Mark Volz, GISP
>     GIS Specialist
>     *From:*geomoose-users-bounces at lists.osgeo.org
>     <mailto:geomoose-users-bounces at lists.osgeo.org>
>     [mailto:geomoose-users-bounces at lists.osgeo.org
>     <mailto:geomoose-users-bounces at lists.osgeo.org>] *On Behalf Of
>     *Robert R. Raiz
>     *Sent:* Tuesday, July 23, 2013 8:04 AM
>     *To:* geomoose-users at lists.osgeo.org
>     <mailto:geomoose-users at lists.osgeo.org>
>     *Subject:* Re: [Geomoose-users] Unsupported output format
>     (image/png;bits=8)
>     Sorry, somehow gmail keyboard shortcuts made a fool out of me and
>     sent the email to soon;
>     The problem is that now, all my png images (PIXMAP) render really
>     badly. They look quite bad.
>     Whatever I try to modify in the map file at the OUTPUTFORMAT
>     parameter, I keep getting:
>     I tried to change every parameter but I still get that error. If I
>     use MIMETYPE "image/png;bits=8" it works with vector files, but my
>     icons (PIXMAP - png images) do not render well.
>     Any Ideas?
>     On Tue, Jul 23, 2013 at 4:00 PM, Robert R. Raiz
>     <raizrobert at gmail.com <mailto:raizrobert at gmail.com>> wrote:
>     Hello all,
>     I am struggling with this error.
>     In the past (with Mapserver5) I was using:
>       IMAGETYPE png24
>     OUTPUTFORMAT
>     NAME 'AGGA'
>     DRIVER 'AGG/PNG'
>     IMAGEMODE RGBA
>     EXTENSION "png"
>     END
>     Now I have:
>     OUTPUTFORMAT
>     NAME "png8"
>     DRIVER AGG/PNG8
>     EXTENSION "png"
>     TRANSPARENT ON
>     IMAGEMODE RGBA
>     FORMATOPTION "QUANTIZE_FORCE=on"
>     FORMATOPTION "QUANTIZE_COLORS=256"
>     FORMATOPTION "INTERLACE=OFF"
>     END
>     */Raiz Roland Robert/*
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130723/d4623c99/attachment-0001.html>
More information about the Geomoose-users mailing list
