[Geomoose-users] strange problem with select
Bistrais, Bob Bob.Bistrais at maine.gov
Wed Jul 31 08:48:18 PDT 2013
Hi Eli,
It appears to be random which adjacent polygons are selected.
Actually, yes, I see the same issue in the demo- try the Select Features tool.  Use a buffer of 20 feet or so, using features in Parcels.  Now select a parcel and hit Go.  You'll see that it selects some of the adjacent parcels, but not all of them (at least not in my testing).  Try it and you'll see what I mean.
If you select just one polygon, then do the "Buffer these results", I am finding it more consistent in selecting the adjacent polygons.
Sent: Wednesday, July 31, 2013 11:20 AM
To: Bistrais, Bob
Cc: geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] strange problem with select
Bob,
On Tue, Jul 30, 2013 at 1:29 PM, Bistrais, Bob <Bob.Bistrais at maine.gov<mailto:Bob.Bistrais at maine.gov>> wrote:
I am working on a GM parcel application (GM 2.6.1).  I was testing the buffered select service.  With no buffering (just select by mouse), it seems to work fine.  On the buffered select I encounter a weird problem.   If you select a parcel, set a buffer distance and query layer (the parcels), click Go- it selects only a few of the surrounding parcels.  In other words, if I set a buffer distance of 50 or 100 I'd expect to get all adjacent parcels selected, but it only selects some of the expected result.
Is it random which ones are selected?  Is it a shift one way or the other?  Area you able to see this in the demo?  Are some never selected?  Do you know if you have invalid/odd geometries or data in those areas?  If you have a PostGIS instance handy, you might want to load it up and run ST_IsValid (http://postgis.net/docs/manual-2.0/ST_IsValid.html) or similar functions to see if there is any pattern of this problem with something that might be in the data.
This isn't a lot of detail to try and figure it out.  You might be able to get more info from checking the requests and responses in firebug (i.e. perhaps it is a bad request vs. bad response vs. bad handling of a correct response, etc).
I hope these ideas lead to something useful.
Eli
The data is a shapefile, if that matters.   Although I had started modifying the select.php for my project, I went back to the original when I discovered the problem, and it's still doing it.  Any idea what's going on?
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130731/f147dd63/attachment-0001.html>
More information about the Geomoose-users mailing list
