[Geomoose-users] GeoMOOSE on portable and hand held devices
Basques, Bob (CI-StPaul) bob.basques at ci.stpaul.mn.us
Tue Jun 18 09:10:25 PDT 2013
Jim,
We've done some experimenting with GeoMoose on Portables.  Some UI redesign and such.  I've also talked with some of the GeoMoose developers about starting up a companion GeoMoose UI specifically for portable use.
Depending on your  remote use limitations, for example running autonomously and standalone presents some interesting wrinkles to the process, you may need to run everything on a portable device, GeoMoose at the very least a WMS service, and/or Mapserver, etc.
I've set things up as a GeoMoose client only approach using the cell connection for data access, as well as setting up a field enabled CPU with a synced copy of the data for fielduse that is not dependent on a data connection.  I've also set up hybrid systems where some layers are local to the field device and others are accessed via the Cell connection.
I would be interested in participating in some joint discussions related to progressing this further within the GeoMoose development community.
Bobb
From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Jim Dahl
Sent: Tuesday, June 18, 2013 10:59 AM
To: Geomoose-users at lists.osgeo.org
Subject: [Geomoose-users] GeoMOOSE on portable and hand held devices
Is anyone aware of any sites having GM designed for portable and hand held devices.  Thanks.
Jim Dahl, GISP
GIS Coordinator
Douglas County Public Works
526 Willow Dr
PO Box 398
Alexandria MN 56308
V 320-762-2933
   320-762-2999
F 320-762-2998
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130618/fdf344d8/attachment.html>
More information about the Geomoose-users mailing list
