[Geomoose-users] Dealing with scales
Brent Fraser bfraser at geoanalytic.com
Wed Jun 19 09:07:34 PDT 2013
Since the difference in the reported scale between Chameleon and
Geomoose is over an order of magnitude, I suspect there is a units
mis-configuration somewhere.  Just where depends on which reported scale
is closer to what's expected...
Best Regards,
Brent Fraser
On 6/19/2013 9:37 AM, Robert R. Raiz wrote:
> Hello James,
> Well, yes, actually for me it is important to know that the  MINSCALE
> / MAXSCALE from map files will be read accordingly in GeoMoose. I need
> the correspondence between them to be correct and to be able to check
> the correct rendering of features.
> I tested today and it seems what I have in the lower right part
> (GeoMoose) is not quite ok compared to what I have in the mapfile (I
> am only referring to scale here);
> To sum up, seeing the big difference between the scales in Chameleon
> and GeoMoose at the same extent, I do not understand how this could
> work. To give a short eg: I have a class rendered in the mapfile
> between MINSCALE 2000 and MAXSCALE 6000. How can see this range
> (class) in GeoMoose if I cannot rely on the scale in the bottom right
> corner.
> Hope I am not missing something here :)
> On Wed, Jun 19, 2013 at 6:08 PM, James Klassen <klassen.js at gmail.com
> <mailto:klassen.js at gmail.com>> wrote:
>     Not really since the browsers don't accurately report screen DPI,
>     so traditional scales in the interactive map are rather
>     meaningless.  The main place the scale is important is to allow
>     printing to a known scale.  Assuming GeoMoose's DPI matches
>     MapServer's (and I think it is at least close), it also helps when
>     setting min/max scale denominators in MapServer layers/classes.
>     The scale reported in the interface (in the drop down in the lower
>     right) is a scale assuming some nominal display DPI.  (Either 72,
>     75 or 96 I think, but would have to check to be sure.)
>     The scales parameter in the mapbook is actually a resolution.  (It
>     is simply passed into OpenLayers to setup the zoom levels,
>     primarily for the popular tiled basemaps.)
>     On Jun 19, 2013 9:41 AM, "Robert R. Raiz" <raizrobert at gmail.com
>     <mailto:raizrobert at gmail.com>> wrote:
>         Oh, as usual, I find something right after I post..
>         I read that "The scales are actually ground units per pixel
>         resolution settings and not true scales. "
>         Is it possible to somehow change this to render actual scales?
>         On Wed, Jun 19, 2013 at 5:33 PM, Robert R. Raiz
>         <raizrobert at gmail.com <mailto:raizrobert at gmail.com>> wrote:
>             Hello all,
>             As I said in a previous post, I am trying to replace the
>             old Chameleon web mapping tool with GeoMoose.
>             Something that I did not quite understand, is why the
>             scales are different in these two mapping tools if they
>             have the same extent;
>             So, I have an extent in the mapfile. Chameleon is giving
>             me a scale of 448286 and in GeoMoose I have 1:35203
>             Can you please tell me what am I missing? I first thought
>             that it has something to do with the ground_units param
>             (as I need the units in feet);
>             Thank you,
>             */Raiz Roland Robert/*
>         _______________________________________________
>         Geomoose-users mailing list
>         Geomoose-users at lists.osgeo.org
>         <mailto:Geomoose-users at lists.osgeo.org>
>         http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130619/310da4d7/attachment.html>
More information about the Geomoose-users mailing list
