[Geomoose-users] EPSG vs ESRI code issue
Robert R. Raiz raizrobert at gmail.com
Tue Nov 5 08:12:07 PST 2013
Hello all,
I am trying to view some data in MO state ESRI projection. Is there any
reason why GeoMOOSE would not work with the ESRI projection considering the
following changes?
I created an ESRI102697.js file in the /../projections folder with the
following params:
*Proj4js.defs["ESRI:102697"] = "+proj=tmerc +lat_0=35.83333333333334
+lon_0=-92.5 +k=0.9999333333333333 +x_0=500000.0000000002 +y_0=0
+ellps=GRS80 +datum=NAD83 +to_meter=0.3048006096012192 +no_defs ";*
I added the *<script type="text/javascript"
src="projections/ESRI102697.js"></script>* line in the *geomoose.html*file.
Is there anything else I would need to do in order to make this work
(except a valid mapfile, of course)? I checked the docs (
http://docs.geomoose.org/2.6/docs/projections.html#include-the-javascript-file-in-your-html)
but I still am not sure if ESRI codes would work.
*Raiz Roland Robert*
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20131105/8b2686c1/attachment.html>
More information about the Geomoose-users mailing list
