[Geomoose-users] EPSG vs ESRI code issue
James Klassen klassen.js at gmail.com
Tue Nov 5 08:32:09 PST 2013
My guess is it will work as far as GeoMoose itself is concerned.  I am not
sure how it will interact with WMS/WFS servers.
In the distant past, I successfully used a made up EPSG code to get a
custom projection (Ramsey County, MN) through WMS.
On Nov 5, 2013 10:12 AM, "Robert R. Raiz" <raizrobert at gmail.com> wrote:
> Hello all,
> I am trying to view some data in MO state ESRI projection. Is there any
> reason why GeoMOOSE would not work with the ESRI projection considering the
> following changes?
> I created an ESRI102697.js file in the /../projections folder with the
> following params:
> *Proj4js.defs["ESRI:102697"] = "+proj=tmerc +lat_0=35.83333333333334
> +lon_0=-92.5 +k=0.9999333333333333 +x_0=500000.0000000002 +y_0=0
> +ellps=GRS80 +datum=NAD83 +to_meter=0.3048006096012192 +no_defs ";*
> I added the *<script type="text/javascript"
> src="projections/ESRI102697.js"></script>* line in the *geomoose.html*file.
> Is there anything else I would need to do in order to make this work
> (except a valid mapfile, of course)? I checked the docs (
> http://docs.geomoose.org/2.6/docs/projections.html#include-the-javascript-file-in-your-html)
> but I still am not sure if ESRI codes would work.
> *Raiz Roland Robert*
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20131105/7f1ff4a9/attachment.html>
More information about the Geomoose-users mailing list
