[Geomoose-users] EPSG vs ESRI code issue
TC Haddad tchaddad at gmail.com
Tue Nov 5 13:55:32 PST 2013
If you are treating this as a fake EPSG code (which does work), you
definitely need to also add it to your Mapserver EPSG file, so that
Mapserver knows how to handle it when it ses in in the map file.
Make sure that the EPSG file you add it to is the one that your copy of
Mapserver is actually using (you may have more than one copy of the EPSG
codes on your system).
On Tue, Nov 5, 2013 at 8:12 AM, Robert R. Raiz <raizrobert at gmail.com> wrote:
> Hello all,
> I am trying to view some data in MO state ESRI projection. Is there any
> reason why GeoMOOSE would not work with the ESRI projection considering the
> following changes?
> I created an ESRI102697.js file in the /../projections folder with the
> following params:
> *Proj4js.defs["ESRI:102697"] = "+proj=tmerc +lat_0=35.83333333333334
> +lon_0=-92.5 +k=0.9999333333333333 +x_0=500000.0000000002 +y_0=0
> +ellps=GRS80 +datum=NAD83 +to_meter=0.3048006096012192 +no_defs ";*
> I added the *<script type="text/javascript"
> src="projections/ESRI102697.js"></script>* line in the *geomoose.html*file.
> Is there anything else I would need to do in order to make this work
> (except a valid mapfile, of course)? I checked the docs (
> http://docs.geomoose.org/2.6/docs/projections.html#include-the-javascript-file-in-your-html)
> but I still am not sure if ESRI codes would work.
> *Raiz Roland Robert*
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20131105/ad2db932/attachment.html>
More information about the Geomoose-users mailing list
