[Geomoose-users] EPSG vs ESRI code issue
Robert R. Raiz raizrobert at gmail.com
Thu Nov 7 00:36:00 PST 2013
Hello again,
I am still struggling with this. I added all those. I do not get the pink
screen. just white background and the message:
*"X,Y: 790038, 980044Lat, Lon: 980043.878, 790037.752USNG: error
lat980043.8781887802 must be between in (-90,90)... no playing at the
poles, yet"*
I read about this in the forums but I do not know what the issue is.. the
shapefile layer looks quite ok. I do not see problems there..
On Tue, Nov 5, 2013 at 11:55 PM, TC Haddad <tchaddad at gmail.com> wrote:
> If you are treating this as a fake EPSG code (which does work), you
> definitely need to also add it to your Mapserver EPSG file, so that
> Mapserver knows how to handle it when it ses in in the map file.
> Make sure that the EPSG file you add it to is the one that your copy of
> Mapserver is actually using (you may have more than one copy of the EPSG
> codes on your system).
> On Tue, Nov 5, 2013 at 8:12 AM, Robert R. Raiz <raizrobert at gmail.com>wrote:
>> Hello all,
>> I am trying to view some data in MO state ESRI projection. Is there any
>> reason why GeoMOOSE would not work with the ESRI projection considering the
>> following changes?
>> I created an ESRI102697.js file in the /../projections folder with the
>> following params:
>> *Proj4js.defs["ESRI:102697"] = "+proj=tmerc +lat_0=35.83333333333334
>> +lon_0=-92.5 +k=0.9999333333333333 +x_0=500000.0000000002 +y_0=0
>> +ellps=GRS80 +datum=NAD83 +to_meter=0.3048006096012192 +no_defs ";*
>> I added the *<script type="text/javascript"
>> src="projections/ESRI102697.js"></script>* line in the *geomoose.html*file.
>> Is there anything else I would need to do in order to make this work
>> (except a valid mapfile, of course)? I checked the docs (
>> http://docs.geomoose.org/2.6/docs/projections.html#include-the-javascript-file-in-your-html)
>> but I still am not sure if ESRI codes would work.
>> *Raiz Roland Robert*
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20131107/f6497278/attachment.html>
More information about the Geomoose-users mailing list
