[Geomoose-users] Hide Identify tool selection
Eli Adam eadam at co.lincoln.or.us
Fri Aug 15 09:56:56 PDT 2014
More shots in the dark:
<service name="identify" title="Identify" display="false">
        <url>php/identify.php</url>
        <step type="spatial" name="shape" show-tools="false" line="false"
polygon="false" jump-start="true" default="point">
        </step>
    </service>
Eli
On Fri, Aug 15, 2014 at 9:45 AM, Dan Little <theduckylittle at gmail.com>
wrote:
> Dang, I took a shot in the dark.  I'll need to play with it tonight.
> There should be a reasonable way for this to work.
> On Fri, Aug 15, 2014 at 11:05 AM, Bistrais, Bob <Bob.Bistrais at maine.gov>
> wrote:
> > Hi Dan,
> > I found that puuting show-tools="false" in the service tab had no
> effect.  Putting it in the <step> tag hid the tools, but then the Identify
> tool doesn't work- your previously-selected tool is still active.  Is there
> another setting that also needs to be changed?
> > ________________________________________
> > From: Dan Little [theduckylittle at gmail.com]
> > Sent: Friday, August 15, 2014 10:29 AM
> > To: Bistrais, Bob
> > Cc: geomoose-users at lists.osgeo.org
> > Subject: Re: [Geomoose-users] Hide Identify tool selection
> > show-tools="false" on the <service > tag?
> > On Thu, Aug 14, 2014 at 3:32 PM, Bistrais, Bob <Bob.Bistrais at maine.gov>
> wrote:
> >> A client has requested that they want only the Draw Box tool to be used
> with
> >> the Identify tool.  It’s easy enough to do that in mapbook.xml.  But
> when
> >> the Identify tool is selected, the radio button for Draw Box still
> appears,
> >> and it’s the only choice, naturally.  The client asked for that to be
> hidden
> >> when the Identify tool is activated.  Can this be done?
> >> (GeoMoose 2.6)
> >> _______________________________________________
> >> Geomoose-users mailing list
> >> Geomoose-users at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140815/eac49e5b/attachment.html>
More information about the Geomoose-users mailing list
