[Geomoose-users] Hide Identify tool selection
Bistrais, Bob Bob.Bistrais at maine.gov
Fri Aug 15 10:10:12 PDT 2014
Thanks guys
It looks like display="false" essentially deactivates the identify tool.
Sent: Friday, August 15, 2014 12:56 PM
To: Dan Little
Cc: Bistrais, Bob; geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] Hide Identify tool selection
More shots in the dark:
<service name="identify" title="Identify" display="false">
        <url>php/identify.php</url>
        <step type="spatial" name="shape" show-tools="false" line="false" polygon="false" jump-start="true" default="point">
        </step>
    </service>
Eli
On Fri, Aug 15, 2014 at 9:45 AM, Dan Little <theduckylittle at gmail.com<mailto:theduckylittle at gmail.com>> wrote:
Dang, I took a shot in the dark.  I'll need to play with it tonight.
There should be a reasonable way for this to work.
On Fri, Aug 15, 2014 at 11:05 AM, Bistrais, Bob <Bob.Bistrais at maine.gov<mailto:Bob.Bistrais at maine.gov>> wrote:
> Hi Dan,
> I found that puuting show-tools="false" in the service tab had no effect.  Putting it in the <step> tag hid the tools, but then the Identify tool doesn't work- your previously-selected tool is still active.  Is there another setting that also needs to be changed?
> ________________________________________
> From: Dan Little [theduckylittle at gmail.com<mailto:theduckylittle at gmail.com>]
> Sent: Friday, August 15, 2014 10:29 AM
> To: Bistrais, Bob
> Cc: geomoose-users at lists.osgeo.org<mailto:geomoose-users at lists.osgeo.org>
> show-tools="false" on the <service > tag?
> On Thu, Aug 14, 2014 at 3:32 PM, Bistrais, Bob <Bob.Bistrais at maine.gov<mailto:Bob.Bistrais at maine.gov>> wrote:
>> A client has requested that they want only the Draw Box tool to be used with
>> the Identify tool.  It’s easy enough to do that in mapbook.xml.  But when
>> the Identify tool is selected, the radio button for Draw Box still appears,
>> and it’s the only choice, naturally.  The client asked for that to be hidden
>> when the Identify tool is activated.  Can this be done?
>> (GeoMoose 2.6)
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140815/b6f6b501/attachment-0001.html>
More information about the Geomoose-users mailing list
