[Geomoose-users] Multiple Maps Configuration
James Klassen klassen.js at gmail.com
Wed Aug 27 13:00:08 PDT 2014
Also be warned, while the HTML/JS code is perfectly fine with alternate
mapbooks, the PHP services may still assume that getmapbook.php returns the
one true mapbook.
On Aug 27, 2014 2:57 PM, "James Klassen" <klassen.js at gmail.com> wrote:
> My guess is you probably need to set the mapserver_url parameter in your
> mapbook.  Normally this is done by getmapbook.php which is bypassed when
> you use mapbook=.
> http://docs.geomoose.org/2.6/docs/configuration.html?highlight=mapbook#mapserver-url
> On Aug 27, 2014 11:14 AM, "Clinton Olsen" <clintono at emery.utah.gov> wrote:
>> I currently have a working geomoose map service using the default
>> mapbook.  I need to display other maps with different layers than what is
>> displayed on the default mapbook.  I found this link that
>> talked about how to reference a different mapbook other than the
>> original.
>> http://docs.geomoose.org/2.6/docs/url_arguments.html
>> geomoose.html?mapbook=../mapbooks/wms_only.xml
>> In order for this to work I created the mapbooks folder under the htdocs
>> folder, and placed a different mapbook under this folder.  The only problem
>> with this setup is when I try to display the shapefile layer.  The geomoose
>> template will display but the layer will not.
>> The normal geomoose mapbook request for the layer starts with the first
>> link below.
>> http://<ipaddress>/cgi-bin/mapserv.exe?
>> The one I am getting when I try to use the other mapbook is below.
>> http://<ipaddress>/geomoose2/FORMAT=image
>> What steps am I missing in order to reference more than one mapbook in my
>> geomoose template?  I have looked under the archives and on the geomoose
>> site but I am unable to find what I need in order to get it working.
>>  Thanks.
>> Clinton Olsen
>> IS/GIS Technician
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140827/350302b4/attachment.html>
More information about the Geomoose-users mailing list
