[Geomoose-users] documentation ideas
James Klassen klassen.js at gmail.com
Wed Dec 23 08:20:40 PST 2015
Introductory material could also assume OSGeo Live which uses a similar
layout to MS4W but under /usr/local/geomoose.   Similarly there are the
build from source on Linux guides I wrote in the GitHub wiki that produce
the standard layout in /srv/geomoose.
Also,  I am starting to think we need at least one line to the effect of
that this is an introduction and not the only way.   I fear people will be
unaware of the power/flexibility present in the design of GeoMoose because
we tend to downplay it in the Intros.   Maybe this material just needs to
be a Chapter 2 or something.
On Dec 23, 2015 10:10 AM, "Dan Little" <theduckylittle at gmail.com> wrote:
> Given Brent's observations, Introductory material should assume ms4w and
> expect linux/UNIX users are advanced enough to adapt.
> On Wednesday, December 23, 2015, Basques, Bob (CI-StPaul) <
> bob.basques at ci.stpaul.mn.us> wrote:
>> All,
>> I agree it’s confusing on it’s own, but if there were more than one
>> server package configuration to look at it wouldn’t seem as mysterious.  I
>> was planning ahead somewhat, with the eventual idea that more of these
>> simple diagrams might appear over time.
>> Should a bare minimum approach to having a running GeoMOOSE be taken then
>> in the diagram.  Also, what would the bare minimum look like?
>> Need APACHE (or ISS) obviously, and . .
>> I can put more detail in into the diagram related to MS4W specifically vs
>> an option where Apache/PHP are installed separately.
>> bobb
>> > On Dec 23, 2015, at 7:15 AM, Dan Little <theduckylittle at gmail.com>
>> wrote:
>> > I think the wording about MS4W is out of place and maybe even
>> confusing.  If you install MS4W then Apache and PHP aren't optional -- they
>> come with the package -- and if someone /just/ installed GeoMOOSE they
>> aren't necessarily going to understand that MS4w is optional in and of
>> itself.  They either (a) had the wherewithal to install it on their
>> platform of choice or (b) installed it from MS4W.  Either way putting the
>> "optional framework" stuff on there could cloud the user's impressions.
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20151223/9afbf610/attachment-0001.html>
More information about the Geomoose-users mailing list
