[Geomoose-users] documentation ideas
Brent Fraser bfraser at geoanalytic.com
Wed Dec 23 08:26:48 PST 2015
Good idea.  A note for those Linux users who read the intro doc would be
good.
My changes to the intro doc assume MS4W.  I'll have to look into OSGeo
Live to understand the implications...
Best Regards,
Brent Fraser
On 12/23/2015 9:20 AM, James Klassen wrote:
> Introductory material could also assume OSGeo Live which uses a
> similar layout to MS4W but under /usr/local/geomoose.   Similarly
> there are the build from source on Linux guides I wrote in the GitHub
> wiki that produce the standard layout in /srv/geomoose.
> Also,  I am starting to think we need at least one line to the effect
> of that this is an introduction and not the only way.   I fear people
> will be unaware of the power/flexibility present in the design of
> GeoMoose because we tend to downplay it in the Intros.   Maybe this
> material just needs to be a Chapter 2 or something.
> On Dec 23, 2015 10:10 AM, "Dan Little" <theduckylittle at gmail.com
> <mailto:theduckylittle at gmail.com>> wrote:
>     Given Brent's observations, Introductory material should assume
>     ms4w and expect linux/UNIX users are advanced enough to adapt.
>     On Wednesday, December 23, 2015, Basques, Bob (CI-StPaul)
>     <bob.basques at ci.stpaul.mn.us <mailto:bob.basques at ci.stpaul.mn.us>>
>     wrote:
>         All,
>         I agree it’s confusing on it’s own, but if there were more
>         than one server package configuration to look at it wouldn’t
>         seem as mysterious.  I was planning ahead somewhat, with the
>         eventual idea that more of these simple diagrams might appear
>         over time.
>         Should a bare minimum approach to having a running GeoMOOSE be
>         taken then in the diagram.  Also, what would the bare minimum
>         look like?
>         Need APACHE (or ISS) obviously, and . .
>         I can put more detail in into the diagram related to MS4W
>         specifically vs an option where Apache/PHP are installed
>         separately.
>         bobb
>         > On Dec 23, 2015, at 7:15 AM, Dan Little
>         <theduckylittle at gmail.com> wrote:
>         > I think the wording about MS4W is out of place and maybe
>         even confusing.  If you install MS4W then Apache and PHP
>         aren't optional -- they come with the package -- and if
>         someone /just/ installed GeoMOOSE they aren't necessarily
>         going to understand that MS4w is optional in and of itself.
>         They either (a) had the wherewithal to install it on their
>         platform of choice or (b) installed it from MS4W.  Either way
>         putting the "optional framework" stuff on there could cloud
>         the user's impressions.
>     _______________________________________________
>     Geomoose-users mailing list
>     Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20151223/ad4f7994/attachment.html>
More information about the Geomoose-users mailing list
