[Geomoose-users] save features
Raffaele Morelli raffaele.morelli at gmail.com
Mon Dec 28 01:45:37 PST 2015
On 23/12/15 at 07:26am, Dan Little wrote:
> You will need to setup a WFS-T server...
> GeoServer: http://docs.geomoose.org/2.8/docs/vector_layers/geoserver_setup.html
> TinyOWS: http://docs.geomoose.org/2.8/docs/vector_layers/tinyows_setup.html
> Enjoy!
> On Wed, Dec 23, 2015 at 7:22 AM, Raffaele Morelli
> <raffaele.morelli at gmail.com> wrote:
> > Hi,
> > how can I save features (points/lines/polygons) in postgis or something else?
> > I am starting to dig into the code and saw some references in
> > GeoMOOSE/MapSource/Vector/WFS.js and geomoose.js
> > Any suggestions?
I've followed the docs using postgis, layer shows up and I've added controls (draw-polygon,
remove-feature and edit-attributes) in layer catalog.
BTW when adding a new feature or editing an existing one, data are not saved in the table.
I've also tested mapserver Openlayers/TinyOWS example and it works like a charm so I
guess the problem is not Postgis related
How can I debug what's going on? TinyOWS log shows nothing about errors and log level is
set to all (15)
Any hint?
«My mama said to get things done
You'd better not mess with Major Tom»
More information about the Geomoose-users mailing list
