[Geomoose-users] save features
Dan Little theduckylittle at gmail.com
Wed Dec 30 11:00:44 PST 2015
Sorry I haven't gotten back to you yet.  I've been working on 2.9 stuff.
Can you attach your mapbook?
On Mon, Dec 28, 2015 at 3:45 AM, Raffaele Morelli
<raffaele.morelli at gmail.com> wrote:
> On 23/12/15 at 07:26am, Dan Little wrote:
>> You will need to setup a WFS-T server...
>> GeoServer: http://docs.geomoose.org/2.8/docs/vector_layers/geoserver_setup.html
>> TinyOWS: http://docs.geomoose.org/2.8/docs/vector_layers/tinyows_setup.html
>> Enjoy!
>> On Wed, Dec 23, 2015 at 7:22 AM, Raffaele Morelli
>> > Hi,
>> > how can I save features (points/lines/polygons) in postgis or something else?
>> > I am starting to dig into the code and saw some references in
>> > GeoMOOSE/MapSource/Vector/WFS.js and geomoose.js
>> > Any suggestions?
> I've followed the docs using postgis, layer shows up and I've added controls (draw-polygon,
> remove-feature and edit-attributes) in layer catalog.
> BTW when adding a new feature or editing an existing one, data are not saved in the table.
> I've also tested mapserver Openlayers/TinyOWS example and it works like a charm so I
> guess the problem is not Postgis related
> How can I debug what's going on? TinyOWS log shows nothing about errors and log level is
> set to all (15)
> Any hint?
> «My mama said to get things done
> You'd better not mess with Major Tom»
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
