[Geomoose-users] save features
Raffaele Morelli raffaele.morelli at gmail.com
Thu Dec 31 00:25:31 PST 2015
On 30/12/15 at 01:00pm, Dan Little wrote:
> Sorry I haven't gotten back to you yet.  I've been working on 2.9 stuff.
> Can you attach your mapbook?
Yep, here we are.
> On Mon, Dec 28, 2015 at 3:45 AM, Raffaele Morelli
> <raffaele.morelli at gmail.com> wrote:
> > On 23/12/15 at 07:26am, Dan Little wrote:
> >> You will need to setup a WFS-T server...
> >> GeoServer: http://docs.geomoose.org/2.8/docs/vector_layers/geoserver_setup.html
> >> TinyOWS: http://docs.geomoose.org/2.8/docs/vector_layers/tinyows_setup.html
> >> Enjoy!
> >> On Wed, Dec 23, 2015 at 7:22 AM, Raffaele Morelli
> >> > Hi,
> >> > how can I save features (points/lines/polygons) in postgis or something else?
> >> > I am starting to dig into the code and saw some references in
> >> > GeoMOOSE/MapSource/Vector/WFS.js and geomoose.js
> >> > Any suggestions?
> > I've followed the docs using postgis, layer shows up and I've added controls (draw-polygon,
> > remove-feature and edit-attributes) in layer catalog.
> > BTW when adding a new feature or editing an existing one, data are not saved in the table.
> > I've also tested mapserver Openlayers/TinyOWS example and it works like a charm so I
> > guess the problem is not Postgis related
> > How can I debug what's going on? TinyOWS log shows nothing about errors and log level is
> > set to all (15)
> > Any hint?
«My mama said to get things done
You'd better not mess with Major Tom»
Type: application/xml
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20151231/ea93bf36/attachment.xml>
More information about the Geomoose-users mailing list
