[Geomoose-users] Identify tool doesn't work
Szymon Wilkowski wilkowskiszymon at gmail.com
Wed Jul 8 11:52:41 PDT 2015
Thanks for your answer, but I can’t find mistake in the mapbook file. Could
you take a look? Perhaps you will find it.
Szymon
2015-07-08 5:59 GMT+02:00 Brent Fraser <bfraser at geoanalytic.com>:
>  Szymon,
>   It could be a problem with your mapbook XML file, specifically the
> map-source definitions?
> Best Regards,
> Brent Fraser
> On 7/7/2015 2:36 AM, Szymon Wilkowski wrote:
>   Hi,
> I am working on my master's thesis, the topic of project being *Design
> and execution of geoportal for the National Park*
> Firstly, I prepared simple project, which a few layers, and now I want to
> check some services.
> I have a problem with identifying service. When I was using examples with
> parcels from the demo everything was working, but when I changed layer to
> something from my database (point layer with hills around the National
> Park) there was an error - *typeError: cannot read property
> 'clearParameters' of undefined*.
> I used the GeoMOOSE Documentation Release 2.7.1 and examples described in
> this book to prepare identify.html file and to change my map file. I think
> I did everything like in example, but as you see I must have made same
> mistake.
> In attachment you can find my .map and identify.html files.
> I will be grateful for your help,
> SzymonW.
> Geomoose-users mailing listGeomoose-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150708/af806a78/attachment-0001.html>
Type: text/xml
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150708/af806a78/attachment-0001.xml>
More information about the Geomoose-users mailing list
