[Geomoose-users] Identify tool doesn't work
Brent Fraser bfraser at geoanalytic.com
Wed Jul 8 16:21:38 PDT 2015
Your Identify service references a hidden map-source/layer of "parcels",
but no map-source of "parcels" exists.  Comment out line 163 of your map
book:
             <input type="hidden" name="hidden_layers"
value="parcels/parcels"/>
Best Regards,
Brent Fraser
On 7/8/2015 12:52 PM, Szymon Wilkowski wrote:
> Thanks for your answer, but I can’t find mistake in the mapbook file.
> Could you take a look? Perhaps you will find it.
> Szymon
> 2015-07-08 5:59 GMT+02:00 Brent Fraser <bfraser at geoanalytic.com
> <mailto:bfraser at geoanalytic.com>>:
>     Szymon,
>       It could be a problem with your mapbook XML file, specifically
>     the map-source definitions?
>     Best Regards,
>     Brent Fraser
>     On 7/7/2015 2:36 AM, Szymon Wilkowski wrote:
>>     Hi,
>>     I am working on my master's thesis, the topic of project being
>>     /Design and execution of geoportal for the National Park/
>>     Firstly, I prepared simple project, which a few layers, and now I
>>     want to check some services.
>>     I have a problem with identifying service. When I was using
>>     examples with parcels from the demo everything was working, but
>>     when I changed layer to something from my database (point layer
>>     with hills around the National Park) there was an error -
>>     /typeError: cannot read property 'clearParameters' of undefined/.
>>     I used the GeoMOOSE Documentation Release 2.7.1 and examples
>>     described in this book to prepare identify.html file and to
>>     change my map file. I think I did everything like in example, but
>>     as you see I must have made same mistake.
>>     In attachment you can find my .map and identify.html files.
>>     I will be grateful for your help,
>>     SzymonW.
>>     _______________________________________________
>>     Geomoose-users mailing list
>>     Geomoose-users at lists.osgeo.org  <mailto:Geomoose-users at lists.osgeo.org>
>>     http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150708/1534828d/attachment.html>
More information about the Geomoose-users mailing list
