[Geomoose-users] Identify tool doesn't work
Szymon Wilkowski wilkowskiszymon at gmail.com
Sat Jul 11 01:46:57 PDT 2015
Ok, I didn't find this earlier, unfortunatley comment out the 163 line
doesn't help.  It still doesn't work and shows the same error.
SzymonW.
2015-07-09 1:21 GMT+02:00 Brent Fraser <bfraser at geoanalytic.com>:
> Your Identify service references a hidden map-source/layer of "parcels",
> but no map-source of "parcels" exists.  Comment out line 163 of your map
> book:
>             <input type="hidden" name="hidden_layers"
> value="parcels/parcels"/>
> Best Regards,
> Brent Fraser
> On 7/8/2015 12:52 PM, Szymon Wilkowski wrote:
>  Thanks for your answer, but I can’t find mistake in the mapbook file.
> Could you take a look? Perhaps you will find it.
>  Szymon
> 2015-07-08 5:59 GMT+02:00 Brent Fraser <bfraser at geoanalytic.com>:
>>  Szymon,
>>   It could be a problem with your mapbook XML file, specifically the
>> map-source definitions?
>> Best Regards,
>> Brent Fraser
>>  On 7/7/2015 2:36 AM, Szymon Wilkowski wrote:
>>    Hi,
>> I am working on my master's thesis, the topic of project being *Design
>> and execution of geoportal for the National Park*
>> Firstly, I prepared simple project, which a few layers, and now I want to
>> check some services.
>> I have a problem with identifying service. When I was using examples with
>> parcels from the demo everything was working, but when I changed layer to
>> something from my database (point layer with hills around the National
>> Park) there was an error - *typeError: cannot read property
>> 'clearParameters' of undefined*.
>> I used the GeoMOOSE Documentation Release 2.7.1 and examples described in
>> this book to prepare identify.html file and to change my map file. I think
>> I did everything like in example, but as you see I must have made same
>> mistake.
>> In attachment you can find my .map and identify.html files.
>> I will be grateful for your help,
>> SzymonW.
>>  _______________________________________________
>> Geomoose-users mailing listGeomoose-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150711/6212b53c/attachment.html>
More information about the Geomoose-users mailing list
