[Geomoose-users] Identify tool doesn't work
Brent Fraser bfraser at geoanalytic.com
Sat Jul 11 10:54:46 PDT 2015
Szymon,
   You should  use your browser's debugger to track down the problem.
Best Regards,
Brent Fraser
On 7/11/2015 2:46 AM, Szymon Wilkowski wrote:
> Ok, I didn't find this earlier, unfortunatley comment out the 163 line
> doesn't help.  It still doesn't work and shows the same error.
> SzymonW.
> 2015-07-09 1:21 GMT+02:00 Brent Fraser <bfraser at geoanalytic.com
> <mailto:bfraser at geoanalytic.com>>:
>     Your Identify service references a hidden map-source/layer of
>     "parcels", but no map-source of "parcels" exists. Comment out line
>     163 of your map book:
>                 <input type="hidden" name="hidden_layers"
>     value="parcels/parcels"/>
>     Best Regards,
>     Brent Fraser
>     On 7/8/2015 12:52 PM, Szymon Wilkowski wrote:
>>     Thanks for your answer, but I can’t find mistake in the mapbook
>>     file. Could you take a look? Perhaps you will find it.
>>     Szymon
>>     2015-07-08 5:59 GMT+02:00 Brent Fraser <bfraser at geoanalytic.com
>>         Szymon,
>>           It could be a problem with your mapbook XML file,
>>         specifically the map-source definitions?
>>         Best Regards,
>>         Brent Fraser
>>         On 7/7/2015 2:36 AM, Szymon Wilkowski wrote:
>>>         Hi,
>>>         I am working on my master's thesis, the topic of project
>>>         being /Design and execution of geoportal for the National Park/
>>>         Firstly, I prepared simple project, which a few layers, and
>>>         now I want to check some services.
>>>         I have a problem with identifying service. When I was using
>>>         examples with parcels from the demo everything was working,
>>>         but when I changed layer to something from my database
>>>         (point layer with hills around the National Park) there was
>>>         an error - /typeError: cannot read property
>>>         'clearParameters' of undefined/.
>>>         I used the GeoMOOSE Documentation Release 2.7.1 and examples
>>>         described in this book to prepare identify.html file and to
>>>         change my map file. I think I did everything like in
>>>         example, but as you see I must have made same mistake.
>>>         In attachment you can find my .map and identify.html files.
>>>         I will be grateful for your help,
>>>         SzymonW.
>>>         _______________________________________________
>>>         Geomoose-users mailing list
>>>         Geomoose-users at lists.osgeo.org  <mailto:Geomoose-users at lists.osgeo.org>
>>>         http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150711/58a0d515/attachment.html>
More information about the Geomoose-users mailing list
