[Geomoose-users] Problem in query.php if layer SRS different from map SRS
TC Haddad tchaddad at gmail.com
Mon Jul 27 11:27:18 PDT 2015
This is drifting into other topics now, but I notice that there are other
data sets already packages with the demo, that are not currently being used
in the interface. e.g. "feedlots", "fire stations", and "pipeline_not_real"
Would any of those be appropriate for these tests?
On Mon, Jul 27, 2015 at 11:06 AM, Brent Fraser <bfraser at geoanalytic.com>
wrote:
>  Wait a minute.  If the parcel data is in UTM then we are already testing
> the multiple SRS case.  Must be the magnitude of the lat/lon coordinates
> causing the problem in queryByRect (and the precision in the search
> template.)
> Best Regards,
> Brent Fraser
> On 7/27/2015 11:42 AM, Basques, Bob (CI-StPaul) wrote:
> All,
>  Should we use the same data in both projections, or two different
> datasets?  I would need to search around for another dataset complete with
> attributes for searching on.
>  I think it would be better to have an entirely separate dataset with
> another projection as an example.
>  The current Parcel dataset is already vetted for redistribution, and
> adding more data to it may take a bit to get going.  Another chunk of data
> alongside of it would be nice, use a different color, different projection
> for sourcing, etc.
>  bobb
>  On Jul 27, 2015, at 12:38 PM, Brent Fraser <bfraser at geoanalytic.com>
> wrote:
>  Bobb,
>   Yes! Change the parcel data to EPSG:4326 and test the rendering,
> Identify, Select Features, Search Parcels, Printing,  and Feature Report
> functions (that would likely decrease my support workload by 80%).
> Best Regards,
> Brent Fraser
> On 7/27/2015 8:17 AM, Basques, Bob (CI-StPaul) wrote:
> All,
>  I wonder if it wouldn’t be prudent to include data from more than one
> projection in order to insure that all reprojection conversions are
> working.
>  bobb
>  On Jul 26, 2015, at 12:37 PM, TC Haddad <tchaddad at gmail.com> wrote:
>  Just as an overall comment, there are 2 very distinct user groups for the
> demo - people who only care about Web Mercator stuff working, and people
> who are trying to work in a local projection.
>  What we have in the demo is working pretty well for the first group, and
> it is a bit unfriendly to beginners in the second group, as projections
> show up in multiple places where beginners are likely to run into trouble
> (e.g. even setting up your zoom levels in the Mapbook.xml). It's compounded
> if a user runs into a bug, and doesn't know it's a bug.
>  Probably worth a review of the docs to see how we might improve in this
> area...
>  Tanya
> On Sun, Jul 26, 2015 at 10:12 AM, Brent Fraser <bfraser at geoanalytic.com>
> wrote:
>> Tanya,
>>   Just by looking at the code in Github I see that there is still no
>> re-projection of the extent before the query call, so i expect that is is
>> still broken (but I will try v2.8).  Now that I'm getting results back I
>> ran into the "zoom to results" bug you've referenced, so that saved me some
>> time.  Thanks!
>> Personally, I think the parcel data in our demo should be in EPSG:4326 so
>> we can discover these problems in our testing before release.
>> Best Regards,
>> Brent Fraser
>>  On 7/26/2015 10:57 AM, TC Haddad wrote:
>>  There was a bug that was fixed recently that may relate:
>>  <https://github.com/geomoose/geomoose/issues/90>
>>  You could try grabbing the relevant changes to query.php:
>> <https://github.com/geomoose/geomoose-services/commit/dacfa7e2648c5bcd3ec38308cb1199621a07c390>
>>  Or you could try a 2.8 install to see if the same problem is present
>> (before filing a new issue...).
>> On Sun, Jul 26, 2015 at 9:32 AM, Brent Fraser < <bfraser at geoanalytic.com>
>> bfraser at geoanalytic.com> wrote:
>>> Hi Developers (and others),
>>>   While debugging a user's problem with using his data with query.php, I
>>> see that line 376 in github (or line 420-ish in GM 2.7.1):
>>>     $ext = $queryLayer->getExtent();
>>> then the layer's extent is used for the query a little later:
>>>     $queryLayer->queryByRect($ext);
>>> This fails to find any features since in my case the coordinate systems
>>> of the map and layer are different, and the queryByrect must be done using
>>> a rectangle in the MAP's SRS not the LAYER's SRS.  I did a little hack to
>>> re-project the extent just before the queryByRect:
>>>                     // re-project the layer's extent into the map SRS
>>> for querying:
>>>                     $map_projection_def = $map->getProjection();
>>>                     $map_projection_obj =
>>> ms_newProjectionObj($map_projection_def);
>>>                     if($queryLayer->getProjection() != NULL) {
>>>                         $projection = $queryLayer->getProjection();
>>>                     if($projection != NULL) {
>>>                         # reproject the query shape as available.
>>>                         $projection = ms_newProjectionObj($projection);
>>>                     if($projection) {
>>>                         $ext->project($projection, $map_projection_obj);
>>>                     if($DEBUG) {
>>>                         error_log(implode(',',
>>> array($ext->minx,$ext->miny,$ext->maxx,$ext->maxy)));
>>>                         error_log("<br/>extent for query in map
>>> SRS.<br/>");
>>> I thought I would get comments before filing an Issue.
>>> So any comments?
>>> Best Regards,
>>> Brent Fraser
>>> Geomoose-users mailing list
>>>  <Geomoose-users at lists.osgeo.org>Geomoose-users at lists.osgeo.org
>>>  <http://lists.osgeo.org/mailman/listinfo/geomoose-users>
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150727/2f08e7e9/attachment-0001.html>
More information about the Geomoose-users mailing list
