[Geomoose-users] Problem in query.php if layer SRS different from map SRS
James Klassen klassen.js at gmail.com
Mon Jul 27 11:29:20 PDT 2015
26915 (or county coordinates) would be more appropriate for the parcel
data.  First it is what it was and second parcels are one of the most
likely layers to be in a local projection.
On Jul 27, 2015 12:38 PM, "Brent Fraser" <bfraser at geoanalytic.com> wrote:
>  Bobb,
>   Yes! Change the parcel data to EPSG:4326 and test the rendering,
> Identify, Select Features, Search Parcels, Printing,  and Feature Report
> functions (that would likely decrease my support workload by 80%).
> Best Regards,
> Brent Fraser
> On 7/27/2015 8:17 AM, Basques, Bob (CI-StPaul) wrote:
> All,
>  I wonder if it wouldn’t be prudent to include data from more than one
> projection in order to insure that all reprojection conversions are
> working.
>  bobb
>  On Jul 26, 2015, at 12:37 PM, TC Haddad <tchaddad at gmail.com> wrote:
>  Just as an overall comment, there are 2 very distinct user groups for the
> demo - people who only care about Web Mercator stuff working, and people
> who are trying to work in a local projection.
>  What we have in the demo is working pretty well for the first group, and
> it is a bit unfriendly to beginners in the second group, as projections
> show up in multiple places where beginners are likely to run into trouble
> (e.g. even setting up your zoom levels in the Mapbook.xml). It's compounded
> if a user runs into a bug, and doesn't know it's a bug.
>  Probably worth a review of the docs to see how we might improve in this
> area...
>  Tanya
> On Sun, Jul 26, 2015 at 10:12 AM, Brent Fraser <bfraser at geoanalytic.com>
> wrote:
>> Tanya,
>>   Just by looking at the code in Github I see that there is still no
>> re-projection of the extent before the query call, so i expect that is is
>> still broken (but I will try v2.8).  Now that I'm getting results back I
>> ran into the "zoom to results" bug you've referenced, so that saved me some
>> time.  Thanks!
>> Personally, I think the parcel data in our demo should be in EPSG:4326 so
>> we can discover these problems in our testing before release.
>> Best Regards,
>> Brent Fraser
>>  On 7/26/2015 10:57 AM, TC Haddad wrote:
>>  There was a bug that was fixed recently that may relate:
>> https://github.com/geomoose/geomoose/issues/90
>>  You could try grabbing the relevant changes to query.php:
>> https://github.com/geomoose/geomoose-services/commit/dacfa7e2648c5bcd3ec38308cb1199621a07c390
>>  Or you could try a 2.8 install to see if the same problem is present
>> (before filing a new issue...).
>> On Sun, Jul 26, 2015 at 9:32 AM, Brent Fraser <bfraser at geoanalytic.com>
>> wrote:
>>> Hi Developers (and others),
>>>   While debugging a user's problem with using his data with query.php, I
>>> see that line 376 in github (or line 420-ish in GM 2.7.1):
>>>     $ext = $queryLayer->getExtent();
>>> then the layer's extent is used for the query a little later:
>>>     $queryLayer->queryByRect($ext);
>>> This fails to find any features since in my case the coordinate systems
>>> of the map and layer are different, and the queryByrect must be done using
>>> a rectangle in the MAP's SRS not the LAYER's SRS.  I did a little hack to
>>> re-project the extent just before the queryByRect:
>>>                     // re-project the layer's extent into the map SRS
>>> for querying:
>>>                     $map_projection_def = $map->getProjection();
>>>                     $map_projection_obj =
>>> ms_newProjectionObj($map_projection_def);
>>>                     if($queryLayer->getProjection() != NULL) {
>>>                         $projection = $queryLayer->getProjection();
>>>                     if($projection != NULL) {
>>>                         # reproject the query shape as available.
>>>                         $projection = ms_newProjectionObj($projection);
>>>                     if($projection) {
>>>                         $ext->project($projection, $map_projection_obj);
>>>                     if($DEBUG) {
>>>                         error_log(implode(',',
>>> array($ext->minx,$ext->miny,$ext->maxx,$ext->maxy)));
>>>                         error_log("<br/>extent for query in map
>>> SRS.<br/>");
>>> I thought I would get comments before filing an Issue.
>>> So any comments?
>>> Best Regards,
>>> Brent Fraser
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150727/534f932a/attachment.html>
More information about the Geomoose-users mailing list
