[Geomoose-users] Problem in query.php if layer SRS different from map SRS
Brent Fraser bfraser at geoanalytic.com
Mon Jul 27 12:38:28 PDT 2015
   That may be true, but it lets too many bugs/limitations through
testing.  And if the functions work for Geographic coordinate data, they
will likely work for projected data sets.
   I think I'll try converting the parcels to geographic coordinates and
see how many functions still work...
Best Regards,
Brent Fraser
On 7/27/2015 12:29 PM, James Klassen wrote:
> 26915 (or county coordinates) would be more appropriate for the parcel
> data.  First it is what it was and second parcels are one of the most
> likely layers to be in a local projection.
> On Jul 27, 2015 12:38 PM, "Brent Fraser" <bfraser at geoanalytic.com
> <mailto:bfraser at geoanalytic.com>> wrote:
>     Bobb,
>       Yes! Change the parcel data to EPSG:4326 and test the rendering,
>     Identify, Select Features, Search Parcels, Printing,  and Feature
>     Report functions (that would likely decrease my support workload
>     by 80%).
>     Best Regards,
>     Brent Fraser
>     On 7/27/2015 8:17 AM, Basques, Bob (CI-StPaul) wrote:
>>     All,
>>     I wonder if it wouldn’t be prudent to include data from more than
>>     one projection in order to insure that all reprojection
>>     conversions are working.
>>     bobb
>>>     On Jul 26, 2015, at 12:37 PM, TC Haddad <tchaddad at gmail.com
>>>     <mailto:tchaddad at gmail.com>> wrote:
>>>     Just as an overall comment, there are 2 very distinct user
>>>     groups for the demo - people who only care about Web Mercator
>>>     stuff working, and people who are trying to work in a local
>>>     projection.
>>>     What we have in the demo is working pretty well for the first
>>>     group, and it is a bit unfriendly to beginners in the second
>>>     group, as projections show up in multiple places where beginners
>>>     are likely to run into trouble (e.g. even setting up your zoom
>>>     levels in the Mapbook.xml). It's compounded if a user runs into
>>>     a bug, and doesn't know it's a bug.
>>>     Probably worth a review of the docs to see how we might improve
>>>     in this area...
>>>     Tanya
>>>     On Sun, Jul 26, 2015 at 10:12 AM, Brent Fraser
>>>     <bfraser at geoanalytic.com <mailto:bfraser at geoanalytic.com>> wrote:
>>>         Tanya,
>>>           Just by looking at the code in Github I see that there is
>>>         still no re-projection of the extent before the query call,
>>>         so i expect that is is still broken (but I will try v2.8).
>>>         Now that I'm getting results back I ran into the "zoom to
>>>         results" bug you've referenced, so that saved me some time.
>>>         Thanks!
>>>         Personally, I think the parcel data in our demo should be in
>>>         EPSG:4326 so we can discover these problems in our testing
>>>         before release.
>>>         Best Regards,
>>>         Brent Fraser
>>>         On 7/26/2015 10:57 AM, TC Haddad wrote:
>>>>         There was a bug that was fixed recently that may relate:
>>>>         https://github.com/geomoose/geomoose/issues/90
>>>>         You could try grabbing the relevant changes to query.php:
>>>>         https://github.com/geomoose/geomoose-services/commit/dacfa7e2648c5bcd3ec38308cb1199621a07c390
>>>>         Or you could try a 2.8 install to see if the same problem
>>>>         is present (before filing a new issue...).
>>>>         On Sun, Jul 26, 2015 at 9:32 AM, Brent Fraser
>>>>         wrote:
>>>>             Hi Developers (and others),
>>>>               While debugging a user's problem with using his data
>>>>             with query.php, I see that line 376 in github (or line
>>>>             420-ish in GM 2.7.1):
>>>>                 $ext = $queryLayer->getExtent();
>>>>             then the layer's extent is used for the query a little
>>>>             later:
>>>>             $queryLayer->queryByRect($ext);
>>>>             This fails to find any features since in my case the
>>>>             coordinate systems of the map and layer are different,
>>>>             and the queryByrect must be done using a rectangle in
>>>>             the MAP's SRS not the LAYER's SRS.  I did a little hack
>>>>             to re-project the extent just before the queryByRect:
>>>>                                 // re-project the layer's extent
>>>>             into the map SRS for querying:
>>>>             $map_projection_def = $map->getProjection();
>>>>             $map_projection_obj =
>>>>             ms_newProjectionObj($map_projection_def);
>>>>             if($queryLayer->getProjection() != NULL) {
>>>>             $projection = $queryLayer->getProjection();
>>>>             if($projection != NULL) {
>>>>                                     # reproject the query shape as
>>>>             available.
>>>>             $projection = ms_newProjectionObj($projection);
>>>>             if($projection) {
>>>>             $ext->project($projection, $map_projection_obj);
>>>>             if($DEBUG) {
>>>>             error_log(implode(',',
>>>>             array($ext->minx,$ext->miny,$ext->maxx,$ext->maxy)));
>>>>             error_log("<br/>extent for query in map SRS.<br/>");
>>>>             I thought I would get comments before filing an Issue.
>>>>             So any comments?
>>>>             Best Regards,
>>>>             Brent Fraser
>>>>             _______________________________________________
>>>>             Geomoose-users mailing list
>>>>             Geomoose-users at lists.osgeo.org
>>>>             <mailto:Geomoose-users at lists.osgeo.org>
>>>>             http://lists.osgeo.org/mailman/listinfo/geomoose-users
>     Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150727/790f7f10/attachment.html>
More information about the Geomoose-users mailing list
