[Geomoose-users] configuring scaleLine.js
Brent Fraser bfraser at geoanalytic.com
Tue Jul 28 10:50:45 PDT 2015
Bob,
   As Jim points out, one approach is to use a mapserver layer to create
an empty map with just a scale bar.  Another approach is to look at
GeoMoose v2.4 and see where the scale_line object is used in the
JavaScript.  It basically just configures the OpenLayers scalebar.  The
advantage of this approach is that it can support the ground distance
instead of just the map distance by including
     if(CONFIGURATION.scale_line.enabled) {
         :            geodesic: true,
This difference can be significant depending on your map projection and
where your are mapping.
Best Regards,
Brent Fraser
On 7/28/2015 10:54 AM, Bistrais, Bob wrote:
> Thanks for the response, Brent.  I haven’t found ScaleLine.js either.
> But then, how do I get a scale bar to appear?
> *From:*Brent Fraser [mailto:bfraser at geoanalytic.com]
> *Sent:* Tuesday, July 28, 2015 12:36 PM
> *To:* Bistrais, Bob; geomoose-users at lists.osgeo.org
> *Subject:* Re: [Geomoose-users] configuring scaleLine.js
> Bob,
> Looks like the ScaleLine object was deprecated in v2.6
> (http://www.geomoose.org/releases/2.6.html), and it was suggested to
> use the ScaleLine.js extension, which I never found
> (http://lists.osgeo.org/pipermail/geomoose-users/2013-April/004895.html)
> Best Regards,
> Brent Fraser
> On 7/28/2015 9:43 AM, Bistrais, Bob wrote:
>     Hello again,
>     Still looking for advice on how to get the scale line working on
>     GeoMoose 2.6.x ?
>     *From:*geomoose-users-bounces at lists.osgeo.org
>     <mailto:geomoose-users-bounces at lists.osgeo.org>
>     [mailto:geomoose-users-bounces at lists.osgeo.org] *On Behalf Of
>     *Bistrais, Bob
>     *Sent:* Thursday, July 23, 2015 3:00 PM
>     *To:* geomoose-users at lists.osgeo.org
>     <mailto:geomoose-users at lists.osgeo.org>
>     *Subject:* [Geomoose-users] configuring scaleLine.js
>     I am trying to enable a scale bar in GeoMoose 2.6.1.  I see that
>     this is now handled through scaleLine.js.  I don’t see any
>     specific document on that, and I haven’t found scaleLine.js in the
>     code.  Can anyone point me to these?
>     Thanks,
>     Bob
>     _______________________________________________
>     Geomoose-users mailing list
>     Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150728/c4244dea/attachment.html>
More information about the Geomoose-users mailing list
