[Geomoose-users] configuring scaleLine.js
Bistrais, Bob Bob.Bistrais at maine.gov
Wed Jul 29 07:29:38 PDT 2015
Brent, Jim, thanks for the suggestions.
I've downloaded 2.4 from the site.  What code files do I find the scale_line object?  Will simply copying this line to my current version 2.6.1 work?
Jim- if you have a chance, can you elaborate on the contents of the mapfile for making the scale bar?
Thanks again,
Bob
From: Brent Fraser [mailto:bfraser at geoanalytic.com]
Sent: Tuesday, July 28, 2015 1:51 PM
To: Bistrais, Bob; geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] configuring scaleLine.js
Bob,
  As Jim points out, one approach is to use a mapserver layer to create an empty map with just a scale bar.  Another approach is to look at GeoMoose v2.4 and see where the scale_line object is used in the JavaScript.  It basically just configures the OpenLayers scalebar.  The advantage of this approach is that it can support the ground distance instead of just the map distance by including
    if(CONFIGURATION.scale_line.enabled) {
        :            geodesic: true,
This difference can be significant depending on your map projection and where your are mapping.
Best Regards,
Brent Fraser
On 7/28/2015 10:54 AM, Bistrais, Bob wrote:
Thanks for the response, Brent.  I haven't found ScaleLine.js either.
But then, how do I get a scale bar to appear?
Sent: Tuesday, July 28, 2015 12:36 PM
To: Bistrais, Bob; geomoose-users at lists.osgeo.org<mailto:geomoose-users at lists.osgeo.org>
Bob,
Looks like the ScaleLine object was deprecated in v2.6 (http://www.geomoose.org/releases/2.6.html), and it was suggested to use the ScaleLine.js extension, which I never found (http://lists.osgeo.org/pipermail/geomoose-users/2013-April/004895.html)
Best Regards,
Brent Fraser
On 7/28/2015 9:43 AM, Bistrais, Bob wrote:
Hello again,
Still looking for advice on how to get the scale line working on GeoMoose 2.6.x ?
From: geomoose-users-bounces at lists.osgeo.org<mailto:geomoose-users-bounces at lists.osgeo.org> [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Bistrais, Bob
Sent: Thursday, July 23, 2015 3:00 PM
To: geomoose-users at lists.osgeo.org<mailto:geomoose-users at lists.osgeo.org>
Subject: [Geomoose-users] configuring scaleLine.js
I am trying to enable a scale bar in GeoMoose 2.6.1.  I see that this is now handled through scaleLine.js.  I don't see any specific document on that, and I haven't found scaleLine.js in the code.  Can anyone point me to these?
Thanks,
Bob
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150729/705ed5ba/attachment-0001.html>
More information about the Geomoose-users mailing list
