[Geomoose-users] Geomoose
Eli Adam eadam at co.lincoln.or.us
Tue Jul 28 12:01:19 PDT 2015
On Fri, Jul 24, 2015 at 12:16 PM, Dan Little <theduckylittle at gmail.com> wrote:
> Can you attach (or put into a Gist or other similar service) the
> contents of the mapfile for the shapefile and your mapbook.xml file?
> On Wed, Jul 22, 2015 at 1:56 PM, Janet Maina <madamjanet92 at gmail.com> wrote:
>> Hey, I have tried to work with geomoose and I was able to load my shapefile.
>> My search is not working and have tried all the possible ways.
>> please explain all the files i need to change.
Here is some documentation that should cover configuring search,
http://docs.geomoose.org/2.8/howto/search.html
>> (Assume I have a field called LRNO )
Sometimes CAPS can cause problems when combined with PostGIS and
MapServer.  For Shapefiles it should be fine, although I believe it is
case sensitive.
Hope this helps, Eli
>> Regards Janet
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
