[Geomoose-users] Geomoose
Brent Fraser bfraser at geoanalytic.com
Tue Jul 28 12:50:41 PDT 2015
Janet,
   Here's a snippet from the doc I've been working on.  maybe it will help.
    Adding Search
If you want to be able search a data source on attribute values, you
will need to:
 1.
    Add input tags to a search service in the mapbook
 2.
    Add METADATA objects for the LAYER in the Mapserver .map file
 3.
    Create a Mapserver template file to display the results
 1.
    Add input tags to mapbook
The easiest way is just to edit the demo mapbook search_parcels service:
<service name="search_parcels" title="Search" clear-highlight="true">
<url>php/query.php</url>
<step type="input">
<input type="hidden" name="layer0"     value="my_source/my_layer"/>
<input type="hidden" name="template0"  value="itemquery"/>
<input type="select" name="fieldname0" title="Search By:">
<option value="ID">Parcel ID</option>
<option value="STATUS">Status</option>
</input>
<input type="hidden" name="comparitor0" value="eq-str"/>
<input type="user"   name="value0" title=""/>
</step>
      </service>
Note the “0” at the end of the name values; it groups them together for
processing.  The option value tags are the column name in your shapefile.
 2.
In the map file for the map-source, add objects to the LAYER’s METADATA
object to indicate the name of the template to use for displaying the
output of the search. You will create the
METADATA
'itemquery' 'templates/search_result.html'
'itemquery-filter' '/.*[qstring].*/i'
END # of METADATA
The entry in the itemquery object is a path relative to the location of
the Mapserver .map file.
 3.
    Create A Mapserver Template
The templates can be simple or complicated depending on what you want to
do with the search results.  Here’s an example of one that will zoom to
the parcel when the link is clicked:
<!-- MapServer Template -->
<b>Parcel ID:</b> <a data-pin="[ID]" id="gm-parcel-[ID]"
class='sprite-control sprite-control-find-selected' style="padding-left:
22px" parcel-shape="[shpxy precision=5]"
href="javascript:GeoMOOSE.zoomToPointsList(dojo.byId('gm-parcel-[ID]').getAttribute('parcel-shape'),
'EPSG:4326');">[ID]</a><br/>
<b>Status:</b> [STATUS]<br/>
<hr/>
Note the “EPSG:4326:” is used because my data is in a Geographic
coordinate system.  If your data is projected, use the same EPSG
definition you used in your Mapserver .map file.
Best Regards,
Brent Fraser
On 7/22/2015 12:56 PM, Janet Maina wrote:
> Hey, I have tried to work with geomoose and I was able to load my
> shapefile.
> My search is not working and have tried all the possible ways.
> please explain all the files i need to change.
> (Assume I have a field called LRNO )
> Regards Janet
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150728/02b7c18a/attachment-0001.html>
More information about the Geomoose-users mailing list
