[Geomoose-users] Feature Reports notes
Brent Fraser bfraser at geoanalytic.com
Mon Jun 1 16:15:54 PDT 2015
I need to correct the information is sent earlier.  The first part of
the instructions below ("Edit the feature_report service...") is not
necessary as the key field name is specified in the template ("<query
item="), not the service definition.
Best Regards,
Brent Fraser
On 6/1/2015 10:57 AM, Brent Fraser wrote:
There doesn't seem to be a lot of documentation for the Feature Report
service, so I made some notes:
Feature Reports
------------------------------------ not necessary:
Edit (or copy) the feature_report service in the mapbook to add the key
field, for example:
    <service name="feature_report_Hydrography" display="false"
keep-others="true">
<url>php/feature_report.php</url>
<input type="hidden" name="layers" value="Backgrounds/osm"/>
<input type="hidden" name="src"/>
<input type="hidden" name="BF_ID"/>
    </service>
Add the metadata to the feature’s map file:
METADATA
'identify_record' 'BF_HYDRO_POLYGON_identify.html'
'popups' 'BF_HYDRO_POLYGON_popups.html'
'feature_report' 'BF_HYDRO_POLYGON_report.xml'
END # of METADATA
Edit the _identify template to add a link to generate and view the
report.  For example my BF_HYDRO_POLYGON_identify.html template has:
<tr><td align="left"><b><a href =
"javascript:GeoMOOSE.startService('feature_report_Hydrography',
{'BF_ID': '[BF_ID]', 'src' : 'Hydrography/Lakes'})">Report</a></b></td></tr>
Create the report xml file (in my case the file is named
BF_HYDRO_POLYGON_report.xml) modifying the key name and the PDF report name:
    <query item="BF_ID" string="%qstring%"/>
    <!-- This is the template -->
    <template>BF_HYDRO_POLYGON_template.pdf</template>
Create the report PDF file
Copy the parcel_template.pdf to the name you entered in the report xml
file, for example:
copy parcel_template.pdf BF_HYDRO_POLYGON_template.pdf
Best Regards,
Brent Fraser
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150601/2c39c246/attachment.html>
More information about the Geomoose-users mailing list
