[Geomoose-users] Feature Reports notes
Brent Fraser bfraser at geoanalytic.com
Mon Jun 1 17:02:18 PDT 2015
Ok, as it turns out it IS necessary to put the key name in the service
definition (so follow my instructions sent at 10:57 below). For now.
I think the fix would be fairly simple:  change feature_report.php to
reference the "PID" parameter (maybe "FID" would be a better name?).
Specifically, change line 67 from:
$layer->setFilter(str_replace('%qstring%', urldecode($_REQUEST[$qItem]),
$query_info->getAttribute('string')));
to
$layer->setFilter(str_replace('%qstring%', $_REQUEST['PID'],
And an implementer would now specify:
<tr><td align="left"><b><a href =
"javascript:GeoMOOSE.startService('*feature_report*', {'*PID*':
'[BF_ID]', 'src' : 'Hydrography/Lakes'})">Report</a></b></td></tr>
(if the layer's unique key was named "BF_ID")
Best Regards,
Brent Fraser
On 6/1/2015 5:15 PM, Brent Fraser wrote:
> I need to correct the information is sent earlier.  The first part of
> the instructions below ("Edit the feature_report service...") is not
> necessary as the key field name is specified in the template ("<query
> item="), not the service definition.
> Best Regards,
> Brent Fraser
> On 6/1/2015 10:57 AM, Brent Fraser wrote:
> There doesn't seem to be a lot of documentation for the Feature Report
> service, so I made some notes:
> Feature Reports
> Edit (or copy) the feature_report service in the mapbook to add the
> key field, for example:
>    <service name="feature_report_Hydrography" display="false"
> keep-others="true">
> <url>php/feature_report.php</url>
> <input type="hidden" name="layers" value="Backgrounds/osm"/>
> <input type="hidden" name="src"/>
> <input type="hidden" name="BF_ID"/>
>    </service>
> Add the metadata to the feature’s map file:
> METADATA
> 'identify_record' 'BF_HYDRO_POLYGON_identify.html'
> 'popups' 'BF_HYDRO_POLYGON_popups.html'
> 'feature_report' 'BF_HYDRO_POLYGON_report.xml'
> END # of METADATA
> Edit the _identify template to add a link to generate and view the
> report.  For example my BF_HYDRO_POLYGON_identify.html template has:
> "javascript:GeoMOOSE.startService('feature_report_Hydrography',
> {'BF_ID': '[BF_ID]', 'src' :
> Create the report xml file (in my case the file is named
> BF_HYDRO_POLYGON_report.xml) modifying the key name and the PDF report
> name:
>    <query item="BF_ID" string="%qstring%"/>
>    <!-- This is the template -->
>    <template>BF_HYDRO_POLYGON_template.pdf</template>
> Create the report PDF file
> Copy the parcel_template.pdf to the name you entered in the report xml
> file, for example:
> copy parcel_template.pdf BF_HYDRO_POLYGON_template.pdf
> Best Regards,
> Brent Fraser
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150601/f692125d/attachment-0001.html>
More information about the Geomoose-users mailing list
