[Geomoose-users] Feature Reports notes
Dan Little theduckylittle at gmail.com
Tue Jun 2 07:35:30 PDT 2015
Brent,
Is there any chance you can create a summarized clarification in an RST doc
or a Google doc? I'm sorry, I don't follow every post to full understanding
so if you can get something I can get more suitable for posting on the docs
website then I'll do it!
Thanks!
On Mon, Jun 1, 2015 at 7:02 PM Brent Fraser <bfraser at geoanalytic.com> wrote:
>  Ok, as it turns out it IS necessary to put the key name in the service
> definition (so follow my instructions sent at 10:57 below).  For now.
> I think the fix would be fairly simple:  change feature_report.php to
> reference the "PID" parameter (maybe "FID" would be a better name?).
> Specifically, change line 67 from:
> $layer->setFilter(str_replace('%qstring%', urldecode($_REQUEST[$qItem]),
> $query_info->getAttribute('string')));
> to
> $layer->setFilter(str_replace('%qstring%', $_REQUEST['PID'],
> And an implementer would now specify:
> <tr><td align="left"><b><a href = "javascript:GeoMOOSE.startService('
> *feature_report*', {'*PID*' : '[BF_ID]', 'src' :
> 'Hydrography/Lakes'})">Report</a></b></td></tr>
> (if the layer's unique key was named "BF_ID")
> Best Regards,
> Brent Fraser
> On 6/1/2015 5:15 PM, Brent Fraser wrote:
> I need to correct the information is sent earlier.  The first part of the
> instructions below ("Edit the feature_report service...") is not necessary
> as the key field name is specified in the template ("<query item="), not
> the service definition.
> Best Regards,
> Brent Fraser
> On 6/1/2015 10:57 AM, Brent Fraser wrote:
>  There doesn't seem to be a lot of documentation for the Feature Report
> service, so I made some notes:
> Feature Reports
> Edit (or copy) the feature_report service in the mapbook to add the key
> field, for example:
>     <service name="feature_report_Hydrography" display="false"
> keep-others="true">
>       <url>php/feature_report.php</url>
>       <input type="hidden" name="layers" value="Backgrounds/osm"/>
>       <input type="hidden" name="src"/>
>       <input type="hidden" name="BF_ID"/>
>    </service>
>  Add the metadata to the feature’s map file:
>        METADATA
>            'identify_record'       'BF_HYDRO_POLYGON_identify.html'
>            'popups'                'BF_HYDRO_POLYGON_popups.html'
>            'feature_report'        'BF_HYDRO_POLYGON_report.xml'
>        END # of METADATA
> Edit the _identify template to add a link to generate and view the
> report.  For example my BF_HYDRO_POLYGON_identify.html template has:
> 'feature_report_Hydrography', {'BF_ID' : '[BF_ID]', 'src' :
> Create the report xml file (in my case the file is named
> BF_HYDRO_POLYGON_report.xml) modifying the key name and the PDF report
> name:
>    <query item="BF_ID" string="%qstring%"/>
>     <!-- This is the template -->
>    <template>BF_HYDRO_POLYGON_template.pdf</template>
> Create the report PDF file
>     Copy the parcel_template.pdf to the name you entered in the report
> xml file, for example:
> copy parcel_template.pdf BF_HYDRO_POLYGON_template.pdf
> Best Regards,
> Brent Fraser
> Geomoose-users mailing listGeomoose-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geomoose-users
>  _______________________________________________
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150602/3037998e/attachment-0001.html>
More information about the Geomoose-users mailing list
