[Geomoose-users] GDB layer problems - Pink Screen
Joshua Meyer jmeyer at lcsheriff.com
Tue Jun 2 10:33:20 PDT 2015
I have tried to add layers from an ESRI geodatabase.  The following error is
received: msOGRFileOpen(): OGR error. Open failed for OGR connection in
layer `ESN'.  File not found or unsupported format.  I originally exported
the layers to shapefiles for testing and they worked.  I have tested each
map file using shp2img with success on each individual layer.  However, when
loading from the mapbook.xml I received the above error.
The gdb file is located in the same folder as the map file.
LAYER
    NAME lafSchools
    TYPE POINT
    CONNECTIONTYPE OGR
    CONNECTION "./Lafayette.gdb"
    DATA "Schools"
Below is the mapbook entry.
<map-source name="lafSchools" type="mapserver">
        <file>./lafayette/ESN/school.map</file>
        <layer name="lafSchools" status="off"/>
        <layer name="lafSchools_anno" status="off"/>
        <param name="FORMAT" value="image/png; mode=8bit"/>
</map-source>
<layer title="Lafayette Schools" src="lafSchools/lafSchools" popups="false"
minscale="3000" maxscale="20000">
</layer>
Joshua Meyer
Lafayette County Sheriff's Office GIS
107 S 11th St
Lexington, MO 64067
Phone: 660-259-2796
Cell: 660-259-1234
Fax: 660-259-2545
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150602/ab53fbd6/attachment.html>
More information about the Geomoose-users mailing list
