[Geomoose-users] GDB layer problems - Pink Screen
Dan Little theduckylittle at gmail.com
Tue Jun 2 11:40:54 PDT 2015
Can you use firebug or chrome's developer tools to see what error is
actually happening? Pink tiles usually indicates a return of a text error
message.
I don't have any specific help on the GDB usage.  If there's an ODBC
problem it very well could be that the web server user does not have the
permissions to do what your local user can do.
On Tue, Jun 2, 2015 at 1:36 PM Joshua Meyer <jmeyer at lcsheriff.com> wrote:
> I have tried to add layers from an ESRI geodatabase.  The following error
> is received: msOGRFileOpen(): OGR error. Open failed for OGR connection in
> layer `ESN'.  File not found or unsupported format.  I originally exported
> the layers to shapefiles for testing and they worked.  I have tested each
> map file using shp2img with success on each individual layer.  However,
> when loading from the mapbook.xml I received the above error.
> The gdb file is located in the same folder as the map file.
> LAYER
>     NAME lafSchools
>     TYPE POINT
>     CONNECTIONTYPE OGR
>     CONNECTION "./Lafayette.gdb"
>     DATA "Schools"
> Below is the mapbook entry.
> <map-source name="lafSchools" type="mapserver">
>         <file>./lafayette/ESN/school.map</file>
>         <layer name="lafSchools" status="off"/>
>         <layer name="lafSchools_anno" status="off"/>
>         <param name="FORMAT" value="image/png; mode=8bit"/>
> </map-source>
> <layer title="Lafayette Schools" src="lafSchools/lafSchools"
> popups="false" minscale="3000" maxscale="20000">
> </layer>
> Joshua Meyer
> Lafayette County Sheriff's Office GIS
> 107 S 11th St
> Lexington, MO 64067
> Phone: 660-259-2796
> Cell: 660-259-1234
> Fax: 660-259-2545
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150602/3676cdcb/attachment.html>
More information about the Geomoose-users mailing list
