[Geomoose-users] GDB layer problems - Pink Screen
Joshua Meyer jmeyer at lcsheriff.com
Tue Jun 2 12:16:53 PDT 2015
I took a look at the page with firebug.  I am getting the error below on the request for the GDB layers.
Reload the page to get source for: http://127.0.0.1/cgi-bin/mapserv.exe?FORMAT=image%2Fpng%3B%20mode%3D8bit&MAP=%2Fms4w%2Fapps%2Fgeomoose2%2Fmaps%2Flafayette%2FESN%2Fschool.map&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&LAYERS=lafSchools&SRS=EPSG%3A3857&BBOX=-10462567.998083,4719295.6982846,-10455999.190965,4720977.3129066&WIDTH=1375&HEIGHT=352
Joshua Meyer
Lafayette County Sheriff's Office GIS
107 S 11th St
Lexington, MO 64067
Phone: 660-259-2796
Cell: 660-259-1234
Fax: 660-259-2545
From: Dan Little [mailto:theduckylittle at gmail.com]
Sent: Tuesday, June 02, 2015 1:41 PM
To: Joshua Meyer; geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] GDB layer problems - Pink Screen
Can you use firebug or chrome's developer tools to see what error is actually happening? Pink tiles usually indicates a return of a text error message.
I don't have any specific help on the GDB usage.  If there's an ODBC problem it very well could be that the web server user does not have the permissions to do what your local user can do.
On Tue, Jun 2, 2015 at 1:36 PM Joshua Meyer <jmeyer at lcsheriff.com> wrote:
I have tried to add layers from an ESRI geodatabase.  The following error is received: msOGRFileOpen(): OGR error. Open failed for OGR connection in layer `ESN'.  File not found or unsupported format.  I originally exported the layers to shapefiles for testing and they worked.  I have tested each map file using shp2img with success on each individual layer.  However, when loading from the mapbook.xml I received the above error.
The gdb file is located in the same folder as the map file.
LAYER
    NAME lafSchools
    TYPE POINT
    CONNECTIONTYPE OGR
    CONNECTION "./Lafayette.gdb"
    DATA "Schools"
Below is the mapbook entry.
<map-source name="lafSchools" type="mapserver">
        <file>./lafayette/ESN/school.map</file>
        <layer name="lafSchools" status="off"/>
        <layer name="lafSchools_anno" status="off"/>
        <param name="FORMAT" value="image/png; mode=8bit"/>
</map-source>
<layer title="Lafayette Schools" src="lafSchools/lafSchools" popups="false" minscale="3000" maxscale="20000">
</layer>
Joshua Meyer
107 S 11th St
Lexington, MO 64067
Phone: 660-259-2796
Cell: 660-259-1234
Fax: 660-259-2545
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150602/28fbbd63/attachment.html>
More information about the Geomoose-users mailing list
