[Geomoose-users] Feature Report error with Identify Tool
Brent Fraser bfraser at geoanalytic.com
Wed Jun 3 07:59:51 PDT 2015
Fernando,
   I don't have any information on MapQuest OSM, so I can't help with
that.  It appears that you are trying to do a Feature Report on a raster
tile, and that will not work.  The Feature  Report service is set up to
work with vector data only.
In general, I'd recommend using some debugging techniques to track down
the problem.  For example:
     - use the browsers built-in debugger (press F12 to enable). Look at
the Network tab to view the URL and parameters the GeoMOOSE JavaScript
sends to the PHP services.
     - use the PHP debug system to log information about the script
     In your php.ini, set the location of the error log:
         error_log = php_errors.log ; (created in htdocs\php)
        In the feature_report.php, set:
    # Debug flag.
    $DEBUG = true; #false;
      Add code to log information, for example:
     if($DEBUG) { error_log("    Set Filter: ".$layer->getFilterString()
   Then by looking at the contents of the log you can determine what is
going wrong.
Best Regards,
Brent Fraser
On 6/3/2015 2:35 AM, Fernando wrote:
> Hello Brent, have now tested your notes on Hydrography OSM. When
> active the MapQuest OSM Catalog type layer many calls are made:
> http://otile1.mqcdn.com/tiles/1.0.0/osm/10/81586/63404.png
> but all have not found 404 results. And when I click on the hyperlink
> "report" of feature_report.php these errors are displayed:
> Warning: ms_newMapObj(): [MapServer Error]: msLoadMap():
> MS_DEFAULT_MAPFILE_PATTERN validation failed.
>  in C:\ms4w\apps\geomoose2\htdocs\php\feature_report.php on line 45
> Warning: ms_newMapObj(): [MapServer Error]: msEvalRegex(): String
> failed expression test.
> Fatal error: Uncaught exception 'MapScriptException' with message
> 'Failed to open map file "/ms4w/apps/geomoose2/maps/"' in
> C:\ms4w\apps\geomoose2\htdocs\php\feature_report.php:45
> Stack trace:
> #0 C:\ms4w\apps\geomoose2\htdocs\php\feature_report.php(45):
> ms_newMapObj('/ms4w/apps/geom...')
> #1 {main}
>   thrown in C:\ms4w\apps\geomoose2\htdocs\php\feature_report.php on
> line 45
> I've seen the Regular expression error. MS_DEFAULT_MAPFILE_PATTERN
> failed validation error when the extension to the map file in the URL
> is incorrect.
> Perhaps the problem is related to my erroneous projection of drawing
> in ArcGIS, but as I said at the beginning of my practice in the
> mailing list for our project does not need any projection, only we
> need the drawing visualize and can be consulted on it. For now we will
> not use the "feature_report". Thanks for everything.
> Date: Mon, 1 Jun 2015 17:09:55 -0600
> From: bfraser at geoanalytic.com
> To: nando_gcia at hotmail.com; geomoose-users at lists.osgeo.org
> Subject: Re: [Geomoose-users] Feature Report error with Identify Tool
> I need to correct the information is sent.  The first part of the
> instructions below ("Edit the feature_report service...") is not
> necessary as the key field name is specified in the template ("<query
> item="), not the service definition.
> Best Regards,
> Brent Fraser
> On 6/1/2015 10:57 AM, Brent Fraser wrote:
>     There doesn't seem to be a lot of documentation for the Feature
>     Report service, so I made some notes:
>         Feature Reports
>     Edit (or copy) the feature_report service in the mapbook to add
>     the key field, for example:
>        <service name="feature_report_Hydrography" display="false"
>     keep-others="true">
>     <url>php/feature_report.php</url>
>     <input type="hidden" name="layers" value="Backgrounds/osm"/>
>     <input type="hidden" name="src"/>
>     <input type="hidden" name="BF_ID"/>
>        </service>
>     Add the metadata to the feature’s map file:
>     METADATA
>     'identify_record' 'BF_HYDRO_POLYGON_identify.html'
>     'popups' 'BF_HYDRO_POLYGON_popups.html'
>     'feature_report' 'BF_HYDRO_POLYGON_report.xml'
>     END # of METADATA
>     Edit the _identify template to add a link to generate and view the
>     report.  For example my BF_HYDRO_POLYGON_identify.html template has:
>     <tr><td align="left"><b><a href =
>     "javascript:GeoMOOSE.startService('feature_report_Hydrography',
>     {'BF_ID': '[BF_ID]', 'src' :
>     'Hydrography/Lakes'})">Report</a></b></td></tr>
>     Create the report xml file (in my case the file is named
>     BF_HYDRO_POLYGON_report.xml) modifying the key name and the PDF
>     report name:
>        <query item="BF_ID" string="%qstring%"/>
>        <!-- This is the template -->
>        <template>BF_HYDRO_POLYGON_template.pdf</template>
>     Create the report PDF file
>     Copy the parcel_template.pdf to the name you entered in the report
>     xml file, for example:
>     copy parcel_template.pdf BF_HYDRO_POLYGON_template.pdf
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150603/fea13146/attachment-0001.html>
More information about the Geomoose-users mailing list
