[Geomoose-users] GeoMOOSE 2.7.1 Print Map
Dan Little theduckylittle at gmail.com
Wed Jun 10 10:38:54 PDT 2015
I've looked at a lot of the relevant print code but we really haven't
changed much.  There *might* be a chance that converting the request
from FORMAT=image/png and TRANSPARENT=TRUE to FORMAT=image/jpeg and
TRANSPARENT=FALSE could help as it will ensure the alphachannel is
always 100%.
On Wed, Jun 10, 2015 at 12:29 PM, Dan Little <theduckylittle at gmail.com> wrote:
> Can you include the relevant <map-source> configuration for the layers
> you want to show up in print? Are you using a local projection or web
> mercator?
> On Tue, Jun 9, 2015 at 7:32 PM, Jenna Walz <jennawalz at co.stevens.mn.us> wrote:
>> 2.6.1
>> ________________________________________
>> From: Dan Little [theduckylittle at gmail.com]
>> Sent: Tuesday, June 09, 2015 4:09 PM
>> To: Jenna Walz; geomoose-users-owner at lists.osgeo.org
>> Subject: Re: GeoMOOSE 2.7.1 Print Map
>> What version are you upgrading from?
>> On Tue, Jun 9, 2015 at 3:47 PM Jenna Walz <jennawalz at co.stevens.mn.us<mailto:jennawalz at co.stevens.mn.us>> wrote:
>> Hello,
>> We recently converted over to GeoMOOSE 2.7.1. We finally got the Print Map tool working. The problem is that our aerial images do not show up when we use the print map tool. It does not show up in a jpg, html, or pdf format. Do you have any suggestions?
>> Thanks,
>> Jenna Walz
>> Jenna Walz
>> Geographic Information Systems Technician
>> (320) 208-6578
>> Stevens County
>> [Stevens County]<http://www.co.stevens.mn.us/>
>> CONFIDENTIALITY NOTICE:
>> This email message and any documents attached to it may contain personal and confidential information which is legally privileged and should be read only by the addressee named above. If you are not the intended recipient, you are hereby notified that any viewing, copying, distribution or storage of this email or its attachments is strictly prohibited. If you received this email in error, please notify us immediately. Thank you for your help.
>> Jenna Walz
>> (320) 208-6578
>> Stevens County
>> [Stevens County] <http://www.co.stevens.mn.us/>
>> Jenna Walz
>> (320) 208-6578
>> Stevens County
More information about the Geomoose-users mailing list
