[Geomoose-users] problem projecting a WMS
TC Haddad tchaddad at gmail.com
Tue Mar 3 14:36:54 PST 2015
Yes that is interesting - I don't know the WMS spec well enough to confirm
if leading numbers are illegal or not. Here's a vaguely relevant blurb from
the spec:
*The Name is a text string used for machine-to-machine communication while
the Title is for the benefit of humans. For example, a dataset might have
the descriptive Title* *“Maximum Atmospheric Temperature” and be requested
using the abbreviated Name “ATMAX”.*
For future archive searchers (or ArcServer admins who are curious about
avoiding this annoying default), the following page lists the configurable
layer properties that can be set in ArcServer:
http://resources.arcgis.com/en/help/main/10.1/index.html#/Available_WMS_service_properties/015400000596000000/
Note that "Use layer names from the map document" is an option that can be
checked, and the table says:
*By default, this option is unchecked, meaning that layers in the WMS
service will be represented with zero-based integers, indicating their
position in the table of contents from the top down.*
*Selecting this checkbox will allow the layer names to be represented with
the same strings that are used in the map document's table of contents. All
the layer names in the map must be unique and cannot contain any of the
characters &, <, >, ", or '. If you need to use one of these characters,
refer to the character substitute table below.*
So, if you run an ArcServer, check this box!
On Tue, Mar 3, 2015 at 12:59 PM, James Klassen <klassen.js at gmail.com> wrote:
> Interestingly the MapServer WMS server gives a warning if you set a layer
> name to start with a number that doing so violates the spec and may not
> work everywhere.
> On Mar 3, 2015 2:22 PM, "TC Haddad" <tchaddad at gmail.com> wrote:
>> For the record Bob, this sort of thing (use of numbers as default layer
>> names in WMS) is common on ArcServers where the admins have not enabled
>> "real" names for services.
>> So, not unique to NWI by any means....
>> On Tue, Mar 3, 2015 at 12:18 PM, Bistrais, Bob <Bob.Bistrais at maine.gov>
>> wrote:
>>>  Think I got it now.  Once I updated the URL, the problem was with the
>>> layer name.  I had the layer name as “Wetlands” (that would seem logical).
>>> But the actual layer name in the WMS is “1”.  I updated mapbook.xml
>>> accordingly, and it works.
>>> I hope this might help others out there.  If you use USFWS NWI service,
>>> please be aware of the layer names!
>>> Bob
>>> *From:* geomoose-users-bounces at lists.osgeo.org [mailto:
>>> geomoose-users-bounces at lists.osgeo.org] *On Behalf Of *Bistrais, Bob
>>> *Sent:* Tuesday, March 03, 2015 3:08 PM
>>> *To:* geomoose-users at lists.osgeo.org
>>> *Subject:* Re: [Geomoose-users] problem projecting a WMS
>>> Correction- I forgot to update the layer name for the Catalog checkbox.
>>> Now that I’ve done that, I get the dreaded pink screen.  Still
>>> investigating on my end, but something’s weird about this updated NWI
>>> service.  Any thoughts?
>>> mailto:geomoose-users-bounces at lists.osgeo.org
>>> <geomoose-users-bounces at lists.osgeo.org>] *On Behalf Of *Bistrais, Bob
>>> *Sent:* Tuesday, March 03, 2015 2:48 PM
>>> *Subject:* [Geomoose-users] problem projecting a WMS
>>> Hello all,
>>> I needed to update my NWI layer references because of an apparent change
>>> by USFWS with the NWI service.  I thought it would be as simple as changing
>>> the URL and/or layer name.  But now the NWI layer does not show at all.  I
>>> am not getting any error messages in Firebug.
>>> Our applications use EPSG:26919 as an SRS.  The NWI services supports
>>> 84, 4326, 3857, and 102100.  In the past I have made this work simply by
>>> setting the map-source projection parameter, but it doesn’t seem to be
>>> working now.
>>> My suspicion is that that the layer is not being reprojected to the
>>> application’s projection, but this worked in the past.  This particular
>>> application is using GeoMoose 2.6RC1.  Here is the code from the
>>> mapbook.xml:
>>>                 <map-source name="nwi" type="wms" reference="false"
>>> tiled="false" projection='EPSG:26919'>
>>>                                 <url>
>>> http://107.20.228.18/ArcGIS/services/Wetlands/MapServer/WMSServer?</url>
>>>                                 <layer name="Wetlands" queryable="true"
>>> status="off"/>
>>>                                                 <param name="format"
>>> value="image/png"/>
>>>                                                 <param
>>> name="TRANSPARENT" value="TRUE"/>
>>>                                                 <param name="STYLES"
>>> value=""/>
>>>                 </map-source>
>>> If it helps, here is the URL to USFWS’s NWI page:
>>> http://www.fws.gov/wetlands/Data/Web-Map-Services.html
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150303/4ac9e0ac/attachment.html>
More information about the Geomoose-users mailing list
