[Geomoose-users] problem projecting a WMS
James Klassen klassen.js at gmail.com
Tue Mar 3 12:19:04 PST 2015
A pink screen means there should be something in Firebug.
Where are you setting the layer projection to one the WMS server
understands?
There is always the slower method of running it through MapServer.
On Mar 3, 2015 2:08 PM, "Bistrais, Bob" <Bob.Bistrais at maine.gov> wrote:
>  Correction- I forgot to update the layer name for the Catalog checkbox.
> Now that I’ve done that, I get the dreaded pink screen.  Still
> investigating on my end, but something’s weird about this updated NWI
> service.  Any thoughts?
> *From:* geomoose-users-bounces at lists.osgeo.org [mailto:
> geomoose-users-bounces at lists.osgeo.org] *On Behalf Of *Bistrais, Bob
> *Sent:* Tuesday, March 03, 2015 2:48 PM
> *To:* geomoose-users at lists.osgeo.org
> *Subject:* [Geomoose-users] problem projecting a WMS
> Hello all,
> I needed to update my NWI layer references because of an apparent change
> by USFWS with the NWI service.  I thought it would be as simple as changing
> the URL and/or layer name.  But now the NWI layer does not show at all.  I
> am not getting any error messages in Firebug.
> Our applications use EPSG:26919 as an SRS.  The NWI services supports 84,
> 4326, 3857, and 102100.  In the past I have made this work simply by
> setting the map-source projection parameter, but it doesn’t seem to be
> working now.
> My suspicion is that that the layer is not being reprojected to the
> application’s projection, but this worked in the past.  This particular
> application is using GeoMoose 2.6RC1.  Here is the code from the
> mapbook.xml:
>                 <map-source name="nwi" type="wms" reference="false"
> tiled="false" projection='EPSG:26919'>
>                                 <url>
> http://107.20.228.18/ArcGIS/services/Wetlands/MapServer/WMSServer?</url>
>                                 <layer name="Wetlands" queryable="true"
> status="off"/>
>                                                 <param name="format"
> value="image/png"/>
>                                                 <param name="TRANSPARENT"
> value="TRUE"/>
>                                                 <param name="STYLES"
> value=""/>
>                 </map-source>
> If it helps, here is the URL to USFWS’s NWI page:
> http://www.fws.gov/wetlands/Data/Web-Map-Services.html
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150303/93bdbb0b/attachment.html>
More information about the Geomoose-users mailing list
